Author Topic: FINISHED - Here comes Peter Pepper - Burgertime Cabaret/Mini scratch build  (Read 17758 times)
shrunkenmaster
As I'm still waiting for my Star Wars cabaret artwork, I thought I'd crack on with my next mini cab - Burgertime.
I got a large format print of the top part. This made it easy to get an accurate profile.
Yesterday was nice and sunny so I managed to get all the woodwork done. First off, cutting the curves with the jigsaw:
Trimming the second piece with the router:
Cutting the t-molding slots:
Using the holesaw for the control panel, speaker panel and marquee top panel, which will have power and credit buttons:
Assembling the cab:
Screen and PC test:
Best progress I've ever made in one day! Artwork to follow...
« Last Edit: September 10, 2011, 06:12:39 am by shrunkenmaster »
Sjaak
  • Last login:March 19, 2025, 02:54:38 am
Re: Here comes Peter Pepper - Burgertime Cabaret/Mini scratch build
« Reply #1 on: August 06, 2011, 04:04:21 am »
1 day  :applaud:
Great job so far
shrunkenmaster
« Reply #2 on: August 06, 2011, 04:28:29 am »
Pretty much finalised the artwork. Control panel:
I searched everywhere for the original marquee artwork but all I found was a lo-res jpeg, so I made this one from scratch using the characters from the CP/bezel:
The side art on Burgertime was originally stencilled. I am going to have full vinyl sides to save the hassle of painting and stencilling:
Still got some work to do on the bezel, mainly resizing the elements to fit my scaled-down cab. More soon...
shrunkenmaster
« Reply #3 on: August 06, 2011, 08:20:57 am »
Bezel done:
Next step, priming and painting...
IG-88
« Reply #4 on: August 06, 2011, 08:37:05 am »
Looks fantastic!   :cheers:
Could you explain how you did the "large format" print for the top part? I've been wanting to do a bartop sized one of these for ages but getting the curves correct has been the sticking point.
Your artwork is top notch also, care to share them with the rest of us?
-HarumaN
shrunkenmaster
« Reply #5 on: August 06, 2011, 10:28:23 am »
Thanks my man. I saved the artwork (just the outlines) as a PDF and got it printed at a local shop that prints up to A0 size. They only print black & white line drawings at that size, which is fine for this.
Happy to share the artwork of course. Here's the Illustrator CS4 & PDF versions of the CPO/Marquee/Bezel (PM me for JPEGS) :
http://www.sendspace.com/file/glwxc3
mgb
  • North East, US
« Reply #6 on: August 06, 2011, 12:01:24 pm »
Very nice job so far. I'm looking forward to seeing the progress.
IG-88
« Reply #7 on: August 06, 2011, 12:17:59 pm »
Thanks a lot for that! I'll PM you later for the jpegs. This should move my project right along now.
Couple more questions if I may. Do you still have the outlines pdf? I would like to try and take that to my local shop and see if they could do the same.
How did you decide on what size for them to print it at? IIRC the mock-up I did for my bartop was just a full size reduced by 2/3 and the upper-half "cut off" a few inches below the CP. Not sure if the side art would look right cut that way but I would really like to figure those curves correctly instead of just winging it.
-HarumaN
shrunkenmaster
« Reply #8 on: August 06, 2011, 01:25:46 pm »
PM sent.
Woodshop Flunky
« Reply #9 on: August 08, 2011, 08:54:45 am »
This is terribly cool!  You're a machine!   :applaud:
How tall is this cab?
IG-88
« Reply #10 on: August 08, 2011, 08:58:33 am »
Got your PM man  :cheers: thanks alot. Now gotta get started on it!!
-HarumaN
shrunkenmaster
« Reply #11 on: August 08, 2011, 09:03:49 am »
Just under 5 feet tall my man.
It's now had 2 primer coats and 2 black coats. Waiting on some speakers to be delivered, then I can install those along with the marquee light. More soon...
shrunkenmaster
« Reply #12 on: August 08, 2011, 12:25:26 pm »
All paintwork done:
Tomorrow I'll get it back upstairs to the funroom for PC/monitor installation.
  • Last login:Yesterday at 06:10:47 am
« Reply #13 on: August 08, 2011, 12:37:05 pm »
Man, you are blasting through this...and it's all top notch quality.  :)
If you don't have a local place or want to do it cheaper, I've used a program called POSTERAZOR.
http://posterazor.sourceforge.net/
It takes your image and divides it up into standard size pdf pages that you print out, then tape together.
shrunkenmaster
« Reply #14 on: August 08, 2011, 12:59:27 pm »
Thanks BadMouth, that's a good alternative. I'm lucky that my local printer does A0 prints for only £3 ($5), plus I never seem to have any ink in my own printer  ;D
extendedplayarcade
  • The Games You Crave
    • Extended Play Arcade
« Reply #15 on: August 08, 2011, 01:11:02 pm »
That is a lot of work done in one day.  Great job.
Looks sharp
shrunkenmaster
« Reply #16 on: August 08, 2011, 01:46:44 pm »
I just thought of a neat way to finish the speaker holes on the panel below the marquee. I had a couple of spare buttons, so I took out the spring/plunger and sawed the switch holder off.
A bit of hot glue, and they provide a nice bezel for that annoyingly catchy 8-bit Burgertime music to pipe through:
« Last Edit: August 08, 2011, 01:52:15 pm by shrunkenmaster »
  • Last login:October 23, 2025, 03:12:48 am
« Reply #17 on: August 08, 2011, 05:40:27 pm »
Here I am struggling to get 1 cab done and here you are turning out beautiful works one after the other!  :cheers:
shrunkenmaster
« Reply #18 on: August 08, 2011, 06:08:39 pm »
Thank Ond  :applaud:
Means a lot coming from you. I love this forum, I've learned many a lesson from yourself and others here.
I must register at tardisyourhouse.com so I can find room for more builds.
shrunkenmaster
« Reply #19 on: August 18, 2011, 10:11:06 am »
Got some of the artwork applied, here's a few shots:
Control Panel:
Here's the marquee. The top panel has a credit button plus a recessed on/off switch:
The MALA menu screen. I wanted it to be simple to understand, so the graphics speak for themselves - move up/down to choose game, press Pepper button to select:
And finally the game:
I have the sideart too, but I need to wait for the orange t-molding before applying. I'm worried the edges of the artwork will be damaged otherwise, as the vinyl will fold over slightly towards the t-molding slot. More soon...
mgb
  • North East, US
« Reply #20 on: August 18, 2011, 10:21:40 am »
awesome job.
awesome theme (I love Burgertime)
awesome frontend. Your Mala layout is perfect, simple and to the point.
very classic. nice work
Woodshop Flunky
« Reply #21 on: August 18, 2011, 11:56:35 am »
Love this cab!  Super envy!  :applaud:
+1 on the front end.  Kudo's on making it blend so well.   :applaud:
« Reply #22 on: August 18, 2011, 02:16:54 pm »
Looks incredible!  Great job, and wow, you move fast!  :applaud:
swaffar
« Reply #23 on: August 18, 2011, 05:33:56 pm »
Awesome!!!  Should I gut my control-panel/cpu and create a proper cabinet or should I make two minis?
My projects:
IG-88
« Reply #24 on: August 18, 2011, 07:27:14 pm »
 :cheers:  Farking Awesome!!  :cheers:
That Mala layout sure is reminiscent of the old game launcher days. Care to share that too?  :applaud:
-HarumaN
shrunkenmaster
« Reply #25 on: August 19, 2011, 07:56:07 am »
Thanks, my man. Here's the layout jpeg, let me know if you want anything else...
Junix
  • Last login:March 31, 2021, 01:23:31 am
« Reply #26 on: August 19, 2011, 11:26:28 am »
Hey, your cabinet is getting very very nice.
Congratulation for your job.
Junix
chopps
  • Last login:August 07, 2025, 09:42:21 pm
« Reply #27 on: August 19, 2011, 12:18:29 pm »
this looks fantastic... great game, and an even better cabinet!!  good job!!  :cheers:
shrunkenmaster
« Reply #28 on: August 19, 2011, 12:23:19 pm »
Thanks for all the kind words guys. As I said previously, this will be on hold for a week or two until the t-molding arrives. I'll be busy back over at Jedi HQ in the meantime:
http://forum.arcadecontrols.com/index.php?topic=111768
shrunkenmaster
FINISHED - Burgertime Cabaret/Mini scratch build
« Reply #29 on: September 10, 2011, 06:10:15 am »
T-molding and sideart applied:
Top view with credit and recessed power switch:
Peter Pepper:
Marquee:
MALA:
Game running:
With his little brothers:
Well Fed Games
  • Last login:October 08, 2025, 04:49:48 pm
  • Delicious!
Re: FINISHED - Here comes Peter Pepper - Burgertime Cabaret/Mini scratch build
« Reply #30 on: September 10, 2011, 08:17:40 am »
Amazing!   :cheers:
nitz
  • Last login:November 24, 2015, 07:57:29 pm
« Reply #31 on: September 15, 2011, 01:15:24 am »
Slightly late to the party here, but just had to comment: This is just awesome. :applaud: :notworthy: Love the early '80s style Midway cabs!
RetroBorg
  • Last login:September 15, 2025, 06:25:47 am
« Reply #32 on: September 15, 2011, 04:30:11 am »
Great cabinet.
« Reply #33 on: September 15, 2011, 02:17:13 pm »
Great turnout!  The cabinet looks beautiful!   :applaud:   :applaud:
Sorry if this was mentioned already, but what monitor is in there?  Its really crisp and bright, at first I thought it was an LCD but it looks pin-cushioned like a CRT.
shrunkenmaster
« Reply #34 on: September 15, 2011, 02:46:45 pm »
Thanks man, the monitor is just a bog-standard Dell. I have smoked plexi on top, then the bezel artwork, then clear plexi. I think the smoked works very well - I didn't need to make a cardboard  bezel for the monitor this way.
sham69
  • Last login:June 12, 2015, 06:03:44 am
« Reply #35 on: September 16, 2011, 05:43:26 am »
Stunning cab , so neat and tidy.
Perfect.
lostinarcade
  • Last login:December 18, 2024, 06:16:52 pm
« Reply #36 on: September 20, 2011, 05:36:34 pm »
i like this one good job.  :applaud:
mmonden
  • Last login:March 05, 2014, 12:17:57 pm
« Reply #37 on: September 20, 2011, 08:37:19 pm »
WOW that was quick.. Great work :applaud:..That Marquee retainer looks rather large. Is that because you use a smaller marquee that fits between the top and bottom wood piece?
Also, I wonder if black T molding below the control panel may look better. Did you consider this?
TopJimmyCooks
« Reply #38 on: September 20, 2011, 08:59:28 pm »
Excellent work.  :cheers:
Bloinkxp
  • Last login:August 30, 2020, 11:20:28 am
« Reply #39 on: September 21, 2011, 01:11:11 am »
Absolutely stunning!  :applaud:
Nothing witty here...move along.
