Author Topic: Router question?  (Read 1941 times)
mytymaus007
Router question?
« on: August 03, 2011, 09:31:28 pm »
upper2bits
  • Last login:December 20, 2011, 05:52:45 pm
Re: Router question?
« Reply #1 on: August 04, 2011, 06:58:02 am »
I would think so, as long as you can get the right bits for it everything should work fine. What type of wood are you using?
BobA
  • What Me Worry?
« Reply #2 on: August 04, 2011, 07:47:30 am »
Cutting joystick base holes etc will take a bit of setup because the router does not look like it has any depth control built in.   You will just have to set your depth of cut on scrap pieces until it is correct.
mytymaus007
« Reply #3 on: August 04, 2011, 08:21:05 am »
what bit do you use for recessing the joysticks. I have the slot cutting bit. I use another bit for the holes with my drill. I just need to recess the sticks and trackball.
BobA
  • What Me Worry?
« Reply #4 on: August 04, 2011, 08:51:23 am »
I use a straight bit.
Straight Bit
  • Last login:May 05, 2024, 08:59:50 am
« Reply #5 on: August 04, 2011, 09:36:59 am »
I have the one from harbor freight (appears to be the same model).
No matter how tight I clamp the depth adjustment, it moves on me.
mytymaus007
« Reply #6 on: August 04, 2011, 03:41:34 pm »
Where you able to rescess joysticks. What were you able to accomplish with your router i actually want to buy the harbor freight trim router only because its $24 what your reiview on the router
thanks
« Reply #7 on: August 04, 2011, 03:59:15 pm »
thanks
I only tested it on a few pieces of scrap and noticed that the cut kept getting deeper as I was routing.
I tightened the depth adjustment to the point that I was afraid it would break, but it still slipped as the router vibrated.
 I was afraid to use it for anything but flush trim work after that.  Read the reviews on harbor freight.
mgb
  • Last login:February 21, 2024, 06:18:13 pm
  • North East, US
« Reply #8 on: August 04, 2011, 10:55:10 pm »
I have a cheapo router from harbor freight and I've used it for trimming the laminate on my cab as well as slotting for t-molding and a few other odds and ends and its held up real well for a $22 router.
bkenobi
« Reply #9 on: August 05, 2011, 11:16:29 am »
thanks
I borrowed a router from my dad for routing the joystick stuff on my CP.  I had the same problem where the bit started slipping out and "auto-adjusted" the depth of the routed path.  I caught it early enough that I was able to fix the problem with just a little extra liquid nail.
In my case, the problem was that the collet was junked up with bits of crap from previous jobs.  After cleaning things up, I was able to get it to work correctly.  I decided to get a new one and return his router in the end since I figured I'd probably need it again at some point.  It's been sitting brand new in the box for ~1.5 years now...  BUT, when I need to do some routing...   :dunno
mytymaus007
« Reply #10 on: August 06, 2011, 04:29:47 pm »
I bought the crappy Harbor freight trim Router $24 plus $7 for bits they sell there. Result exactly what i wanted. I was able to use one hand to complete job. next i will recess the joysticks and volcano buttonsif i ever get any!
syph007
« Reply #11 on: August 06, 2011, 05:33:37 pm »
Perfectly straight cuts too!!!
LOL I kid I kid....  ;D
I know how tool costs add up.  I think I spent over 500 on tools my first build.  But now my second build is much cheaper!
mytymaus007
« Reply #12 on: August 06, 2011, 08:26:39 pm »
LOL this was free hand (one hand) and first time with a router. im actually puting a marquee over this just needed to route out more wood to get some more light behind it.
