May 07, 2024, 08:09:09 pm
So, Jakobud. Basically, if I go measure up my cabinets, and then make some basic drawings, and send you the info, then you can make up some plans?
So, Jakobud. Basically, if I go measure up my cabinets, and then make some basic drawings, and send you the info, then you can make up some plans?Right on! With your OK, I will start measuring my Midway 8080 cabinet tommorrow.
Okay so I used to do a lot of AutoCAD for a living and could easily draw up all of these plans in a standard format that anyone could use and read easily. And then I could host them on my website (cause wading thru this thread, I can't tell where these things are being hosted). I could do some major cleanup work on these drawings and if anyone wanted me to draw up some plans from scratch I could easily do that too. I could host the Autocad files and maybe PDF conversions of everything too. Would anyone be interested in me doing this?
nicely done!Intent to measure-Tempest and tron this week sometime--i will detail tron a bit since someone is seriously looking to build a replica. an others?available:berzerkasteroidsfast freddiebattlezoneturbopole position
I added Lusid's Arcade Flashback drawings to my site last night. I'll add a few more tonight.www.jakobud.com
Okay if you can point me to some of the plans out there for a MS Pacman cocktail then I would be happy to draw them up.I am currently working on both Pacman/Galaxian and Ms Pacman/Galaga cabinets but I'm finding it difficult to create dimensions for the long curved shapes in them. Its hard to create dimensions for the curves in a way that someone else can look at it and understand how to exactly reproduce the same curvature...
