Author Topic: RGB LED backlighting suggestions  (Read 1263 times)
neohusky
  • Last login:March 25, 2022, 09:10:44 pm
« on: July 31, 2011, 11:17:24 am »
Hi All
I'm considering having a marquee made of raw MDF with a logo cut out of it.  What would be the best way to light the logo from behind? I'd prefer an rgb LED solution so I can run it through a PacLED64 so I can change the lighting effect when in attract mode.
There are 2 solutions I'm considering.
1. to cover the inside of the marquee cutout with frosted plexiglass and back light it.
2. attempt to edge light the plexiglass although not sure on how effective it would be.  Not sure of the size of the LEDs (Ultralux RGB/IL-lumination RGB 5VDC LED) and thickness of plexi required.
This raises a few questions.  Which of the 2 methods would create a good result using a minimum of LEDs? Is there a better way to do this?
Re: RGB LED backlighting suggestions
« Reply #1 on: July 31, 2011, 11:36:37 am »
You could use something like these for the backlighting. They can be seperated into 3-LED segments (and would have to be seperated to use with the PACLED64). Each segment would use 3 terminals (4 if you gave each segment its own +) of the PACLED64, so you would be able to light 21 of those segments. Keep that in mind if you have other LEDs to light on your cab.
drawfull
« Reply #2 on: July 31, 2011, 01:58:35 pm »
How much do you need? I have about 2m of KKDC RGB led strip and power supply that I don't have a use for. PSU is 240VAC input* (edited) tho.
« Last Edit: July 31, 2011, 02:00:43 pm by drawfull »
neohusky
« Reply #3 on: August 01, 2011, 08:32:44 pm »
These are all excellent suggestions. I've got the PAC64s and pushbuttons LEDs waiting for the cp to be built.  I'll be testing with these and also consider trying some strip LEDs during my tests.
I'd love to get the strip lighting off drawfull, but, I live in Aus. Shipping would be a bit pricey.
« Reply #4 on: August 01, 2011, 08:36:05 pm »
There are many different suppliers for the strip LEDs. You should be able to find someone that offers reasonable shipping, might even be able to find onein Aus.
neohusky
« Reply #5 on: August 01, 2011, 08:49:54 pm »
There's a few sellers on eBay that offer global shipping.
drawfull
« Reply #6 on: August 02, 2011, 03:59:19 am »
Didn't realise you were down there. KKDC are an Australian company though...
BobA
  • What Me Worry?
« Reply #7 on: August 02, 2011, 06:19:13 pm »
Lots of choices from dealextreme and the shipping is free.  Couple of examples
rgb led strip
rgb led strip
