May 08, 2024, 02:38:01 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Forum notices to gmail.com addresses are working. Microsoft addresses are still not.
The NEW Build Your Own Arcade Controls
Main
Main Forum
Is Particleboard okay if I'm using laminate over it?
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Is Particleboard okay if I'm using laminate over it? (Read 1317 times)
upper2bits
Trade Count:
0
Full Member
Offline
Last login:December 20, 2011, 05:52:45 pm
on:
July 30, 2011, 10:02:44 am »
I want the t-molding to line up and I can't find 5/8 mdf or plywood so I'm stuck with Particleboard. If one side will have laminate is Particleboard okay to use?
Logged
upper2bits
Trade Count:
0
Full Member
Offline
Re: Is Particleboard okay if I'm using laminate over it?
Reply #1 on:
July 30, 2011, 10:06:20 am »
Actually, doing a little more reading it it appears that the laminate is only 1/32" think so 3/4 MDF with that might fit with 3/4 t-molding. No?
Logged
upper2bits
Trade Count:
0
Full Member
Offline
Reply #2 on:
July 30, 2011, 10:20:49 am »
More reading, would it work to just use 3/4 mdf, 1/16 laminate and then get 13/16 tmodling?
Logged
JRChristenson
Trade Count:
0
Full Member
Offline
Last login:August 28, 2020, 05:29:39 pm
Reply #3 on:
July 30, 2011, 11:56:26 am »
I used particleboard for my painted bartop and it's coming out fine. I would definitely use it if I was laminating, much cheaper than mdf or plywood.
Logged
Knightlore
Trade Count:
0
Full Member
Offline
Last login:June 04, 2014, 07:44:55 am
Reply #4 on:
July 30, 2011, 12:02:16 pm »
Well I took delivery a few weeks ago of a pre-build cocktail cab, it's laminated particle board (or chipboard as we call it over here) and it's absolutely fine, very sturdy indeed.
Logged
syph007
Trade Count:
+2
Full Member
Offline
Last login:June 24, 2014, 04:30:03 pm
With a router big enough, we can shape the world!
Reply #5 on:
July 31, 2011, 09:51:32 am »
my experience is that it is just ok. The edges of it have a tendency to crumble. I now only use it for mockups or templating. MDF holds up better, but its nastier to work with, which is why I use particle board still for some jobs. Routing the t-molding slot in particle board wont leave as nice of slot as other material. But yes it will be covered up. So I guess its probably fine, but I wouldnt recommend.
Edit: Looks like pinballjim is using particleboard. See the edges for what I was talking about.
http://forum.arcadecontrols.com/index.php?topic=113417.0
Last Edit: July 31, 2011, 09:54:23 am by syph007
Logged
First Laminated Full Size Cab
2P folding bartop
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
