Main > Project Announcements
outrun project
Pages: << < (2/3) > >>
Pinball Wizard:
One issue to look out forit that the speakers on top often monitormay discolor it over time.
BadMouth:
--- Quote from: Pinball Wizard on July 11, 2011, 08:24:42 am ---One issue to look out forit that the speakers on top often monitormay discolor it over time.
He's using PC speakers, so it won't be a problem;they're shielded.
Namco:
Wow, that looks great. I wonder if the PC has a version of Outrun that will take advantage of that wheel's force feedback, that would be incredible. Also I think you missed a great opportunity to mount speakers by the player's head. Having some bumping speakers next to the player is something I remember from a few cockpit drivers. I have an old TSW2 steering wheel that I have been dying to put into a cabinet. This is giving me some ideas. ;D
BadMouth:
--- Quote from: Namco on July 11, 2011, 10:14:25 am ---I wonder if the PC has a version of Outrun that will take advantage of that wheel's force feedback, that would be incredible.
http://www.oocities.org/finalburnff/
Your question got me looking into this again.  I'd heard there was a version of Final Burn that supported FFB, but all I came across before were some code to add to the newer build to add rumble support.  That doesn't do anything for wheels.  After your comment, I searched again and found the link above and it sounded like it worked with an actual wheel.  I gave it a try and it does!!!
Setup is a bit of a PITA.  I don't want to derail jackiabu's thread with the details.
I'll add them to the driving cab thread shortly and mark it as updated as of today.
jackiabu:
--- Quote from: BadMouth on July 09, 2011, 03:58:27 pm ---
--- Quote from: jackiabu on July 09, 2011, 02:01:46 pm ---
First of all thank you very much for your help. :laugh:
Listen I think you're really an expert in the field of car-style arcade machine.
Anyway I downloaded the emulator of NEBLUA SEGA and it's not working for me, can you help me with this?
I downloaded the file from the site but I opened it but nothing happens.  :banghead:
The newest release requires that your runtimes be up to date:
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=5555
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=35
The roms it uses are the same as MAME.
If it still doesn't work, let us know exactly what it's doing.
ok i download the file m2 emulator,extract and run it.my question is where i put the rom file? :-\
thanks ahead
Go to full version
