Author Topic: PCB mounting feet (need like 20 sets of 4)  (Read 3246 times)
runawayabc123
  • Last login:September 06, 2019, 09:58:20 am
« on: July 08, 2011, 11:16:30 pm »
Where is a good place to get like 20 sets of PCB mounting feet.  I don't want to spend more than about $16 shipped as I can make my own past that price.  Most people seem to want like 1.50-2.00 per set.  Yikes!
mytymaus007
Re: PCB mounting feet (need like 20 sets of 4)
« Reply #1 on: July 09, 2011, 12:38:31 am »
Glue them on cheapest no hassle and its free if you have glue :laugh2:
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« Reply #2 on: July 09, 2011, 07:02:27 am »
I've never done it before but I've heard a lot of people say just remove the ink out of a bic pen and cut the remaining empty tube into a few short pieces and use those
syph007
« Reply #3 on: July 09, 2011, 08:40:24 am »
Hardware store plumbing aisle.  Roll of hard white tubing, and make all you need for a few bucks.
gabe
  • Last login:September 10, 2012, 12:44:38 pm
« Reply #4 on: July 09, 2011, 03:03:53 pm »
"Why didn't I think of that?"
Great tip, thanks!
Minions
  • Last login:March 28, 2021, 01:43:57 pm
« Reply #5 on: July 09, 2011, 03:58:49 pm »
I used the bic pen method. Set the ink aside, can always pop those back in pens once they run out and still get use out of the ink. Win win in my book as you can get large packs of those pens for next to nothing.
jimmy2x2x
« Reply #6 on: July 09, 2011, 04:02:04 pm »
Do you not find the bic pen solution brittle when cutting and fragile when in use?
The tubing solution looks great to me
Minions
« Reply #7 on: July 09, 2011, 04:15:46 pm »
I normally use a saw to cut them, anything with small teeth, and I'm not jumping on these things, all they need to do is separate the board from whatever I attach it to. Just drop a screw from the top of the board through the pen and into the wood or whatever.
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #8 on: July 09, 2011, 04:29:36 pm »
You could even use rubber "feet" with a screw hole thru them....just snug them down...no need to torque them to hell...
http://angela.com/images/products/detail/MouserFeetWebsite4RFA.1.jpg
Your hardware likely has them for a quarter....
runawayabc123
« Reply #9 on: July 09, 2011, 11:00:16 pm »
Yeah, I think it might be time to make my own.  Just figured the actual feed have to be cheap somewhere.
runawayabc123
« Reply #10 on: July 10, 2011, 07:28:55 pm »
Ok, I got the tubing and a bunch of screws/nuts for about 12 boards for $5.
What kind of screws did you get?  I couldn't find any plastic washers... so I will have to make those too.
Also, how are you cuting the tubing?  Side cutters?  How badly does it crush?
The greed of the pcb feet people have lost out today.   :applaud:
syph007
« Reply #11 on: July 10, 2011, 07:31:54 pm »
I just used a very sharp knife to cut the tube.  I used nylon washers on top, which home depot had.  Really though you could just cut a small piece of tube for a washer.  Then just find some screws with a large flat head and you're good to go.
milkit
  • Last login:June 28, 2014, 09:14:33 pm
« Reply #12 on: July 11, 2011, 10:08:38 am »
i have a ton, $.90 per set of 4
