Author Topic: The cutest mouse "hack" you ever did see  (Read 4242 times)
Generic Eric
  • Last login:March 05, 2024, 09:02:23 am
« on: July 05, 2011, 09:41:26 pm »
I saw this on ebay and bought it.  I thought it was pretty cool. It doesn't have force feed back though.  Its very simple setup that requires a "ball" mouse to work.
Here is the box.
Here are the basic components
The table mount bracket.
The steering "column"
Well, I lost the pic, but imagine a piece of 1 inch  pvc pipe about 10 or 12 inches long
The steering wheel
The base
With the "gear box"
All together.
It will also function as a yoke for flight controllers.   About this unit:  The specs of the mount and the part that holds the "steering column" weren't matched well so there is a little more play than I'd like to see.
I thought I would provide this to show that a person can get a working prototype unit for a small investment of random basic components.
« Last Edit: January 06, 2015, 12:43:05 pm by Generic Eric »
Corbo
  • Last login:June 24, 2019, 07:49:12 am
  • I've not seen such bravery
    • Minicade - Mini Gauntlet MAME project
Re: The cutest mouse "hack" you ever did see
« Reply #1 on: July 06, 2011, 09:55:46 am »
Is that a ball mouse or a laser mouse?
_____________________
Wizard needs food, badly!
My mini arcade project:  http://minicade.blogspot.com/
Generic Eric
« Reply #2 on: July 06, 2011, 10:18:27 am »
Ball.  missed that.  Thanks
If anyone has anymore questions, feel free to ask.
« Last Edit: July 06, 2011, 10:20:35 am by Generic Eric »
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #3 on: July 06, 2011, 11:47:43 am »
You sponsored by diet coke or something  ;D
lilshawn
  • Last login:May 06, 2024, 08:27:40 pm
« Reply #4 on: July 06, 2011, 12:24:09 pm »
hilarious!
i would think an optical mouse would work as well.
  • Last login:May 05, 2024, 08:59:50 am
« Reply #5 on: July 06, 2011, 12:38:15 pm »
I experimented with an optical mouse on the backside of the steering wheel hub and it seemed to work fine.
(only played for a couple minutes)
Never thought of it working on two axis!
Someone could build a cheap flight yoke out of pvc or use one of those wii steering wheels that they sell at dollar tree for $1.
migraineman
  • Last login:July 01, 2016, 02:56:35 pm
« Reply #6 on: July 06, 2011, 06:29:52 pm »
How about the Trojan Attack Mouse?
http://pentest.snosoft.com/2011/06/24/netragards-hacker-interface-device-hid/
An elegant attack vector, definitely a hack, and "cute" for certain definitions of the term.  You can't trust nuthin' anymore.  If your new USB mouse mounts as a mouse, a keyboard, and a mass-storage device, you should be concerned.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 08:37:55 pm
« Reply #7 on: July 07, 2011, 11:42:58 am »
the old MS-Mouse that had used POT inside instead of the standard WHEEL/Optical type mouse would probably work very good.
Free VGA Breakout Cable
lilshawn
« Reply #8 on: July 07, 2011, 01:15:04 pm »
Pot?
 Must have been designed in the 60's... Man.
Generic Eric
« Reply #9 on: July 07, 2011, 08:17:43 pm »
I'll keep an eye out, I'll have to get another mouse.  The mice I have already have purpose and can't be sacrificed.
There are some cool designs out there.  Lew has a good design.
  I found another well done design used by someone into flight simulators
http://buggies.builtforfun.co.uk/Sim/FFB-yoke-1.php
« Last Edit: July 07, 2011, 08:31:55 pm by Generic Eric »
