Author Topic: having a hard time with a mortal kombat  (Read 1875 times)
redfivexw
  • Last login:March 03, 2022, 04:49:56 pm
« on: June 29, 2011, 02:08:35 pm »
Ok,
i have a mortal kombat machine that a friend asked me to work on.  Here is the problem.  The machine had a bad power supply, i replaced it with a switching unit.  I cannot get any sound out of it.  I know the boards are good because i checked them with my own Mortal Kombat setup.  Is there something i should be looking for, because i really cannot figure it out!
  • Last login:May 06, 2024, 04:33:26 pm
Re: having a hard time with a mortal kombat
« Reply #1 on: June 29, 2011, 02:10:22 pm »
Try turning the volume pot?  I know my volume pot in my MK is a little flakey...
« Reply #2 on: June 29, 2011, 02:10:47 pm »
You should see it when you open the coin door...
  • Last login:Yesterday at 09:56:41 pm
« Reply #3 on: June 29, 2011, 02:16:36 pm »
did you already try a different jamma board in the cab for sound?
postmortem
  • Last login:July 03, 2020, 10:58:40 am
« Reply #4 on: June 29, 2011, 03:00:59 pm »
bad speakers?
Cabs: Tron, MKII, MK4, KI2, Blitz99, TMNT, Pac-Mania, Defender, Mame Box.
PCBs: MK1, UMK3, Killer Instinct, Area51, Sunset Riders, Pit Fighter, Wargods.
Pins: Bride of PinBot, Attack from Mars, The Shadow
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
« Reply #5 on: June 29, 2011, 03:04:57 pm »
Other jamma boards work with sound?
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
redfivexw
« Reply #6 on: July 04, 2011, 09:44:26 am »
i tried all those things, i cannot seem to track down the issue, i am going to spend some time today on it.  It has me baffled.
DaveMMR
    • TeeVee Games
« Reply #7 on: July 04, 2011, 09:54:11 am »
Is Mortal Kombat one of those games where you have to go into service mode to adjust the default volume?  I know I had to do that with MKII and MK3 (the Mame versions, that is).
  • Last login:March 21, 2024, 08:20:28 am
« Reply #8 on: July 04, 2011, 01:53:02 pm »
Could be a short in one of the wires. I would also try taking a multimeter to each end of every speaker/volume wires to make sure you are getting a connection.
Q*Bert_OP
  • Oh yes, we did!
« Reply #9 on: July 04, 2011, 04:07:34 pm »
Check the ribbon cable between the sound PCB and MPU. Make sure its on correctly(red stripe to pin 1 on both sides). Try squeezing the connectors with pliers. I have an NBA Jam out that has a flaky ribbon cable.
All cables that go between sound pcb and MPU present?
-5v present?
