Main > Main Forum
having a hard time with a mortal kombat
Pages: << < (2/2)
Scott84:
Other jamma boards work with sound?
redfivexw:
i tried all those things, i cannot seem to track down the issue, i am going to spend some time today on it.  It has me baffled.
DaveMMR:
Is Mortal Kombat one of those games where you have to go into service mode to adjust the default volume?  I know I had to do that with MKII and MK3 (the Mame versions, that is).
Vigo:
Could be a short in one of the wires. I would also try taking a multimeter to each end of every speaker/volume wires to make sure you are getting a connection.
Q*Bert_OP:
Check the ribbon cable between the sound PCB and MPU. Make sure its on correctly(red stripe to pin 1 on both sides). Try squeezing the connectors with pliers. I have an NBA Jam out that has a flaky ribbon cable.
All cables that go between sound pcb and MPU present?
-5v present?
Pages: << < (2/2)
Go to full version
