Main > Main Forum
Happ trackball USB problem...
Vidiot:
Just an update to this situation. I have verified that I have connected the ground wire to the main ground wire with my buttons so I don't think there is a problem there. I have contacted arcadeemulator.net about possibly obtaining a USB cable for my I-PAC and also maybe a replacement circuit board for my trackball (Part # 55-0301-00). I would like to try the I-PAC in USB mode so I can use the trackball in PS/2 mode. My I-PAC is an older model made in 2003 but it does support USB mode. If that doesn't work for some reason then I will replace the circuit board on the trackball. I'll continue to post my progress in case it helps someone else.
Vidiot:
Just thought I'd post another update in case anyone is following this. I have received the replacement circuit board from divemaster. Seems to have fixed my problem. :)
Hoopz:
timply:
I also have the 55-0301-00 Happs board and has been giving me the same problems. Can i get a link to the to the place where you got the replacement boards? Or do I need to contact divemaster personally?
Vidiot:
--- Quote from: timply on August 27, 2012, 12:00:31 am ---I also have the 55-0301-00 Happs board and has been giving me the same problems. Can i get a link to the to the place where you got the replacement boards? Or do I need to contact divemaster personally?
I think I just contacted him directly through email to inquire about them. His website is http://www.arcadeemulator.net/
