Main > Main Forum
DIY Arcade Help & Ideas Welcome
<< < (2/2)
comicsans:
heres a video of a completed project
comicsans:
ChurchOfSolipsism:
--- Quote from: Donkbaca on June 28, 2011, 05:08:57 pm ---
I would get the mad catz fight pads from vpgames.com, they are only 23 bucks a pop and easy to hack, that is what I did.
+1. If you throw the buttons away anyway then all you're left with is a PCB and a stick that, from what I've heard, is a tad on the crappy side. Get a Japanese quality stick from Sanwa or Seimitsu and buy what donkbaca recommended or one of these for an easy-to-solder-to PCB:
http://www.amazon.co.uk/Arcade-Games-Stick-Xbox-360/dp/B000MCHETQ/ref=sr_1_15?ie=UTF8&qid=1309523229&sr=8-15
comicsans:
ive got a mad catz se which you can mod up with sanwa parts so im going to take it out of the case and use the top as a template on the control panel.
i should get the kit tommrow so i will take pictures and start a project thread. I am a bit worried about screwing into the control panel if its pvc ill have to see when it comes.
SavannahLion:
--- Quote from: BobA on June 29, 2011, 12:51:10 am ---Did you notice that the kit seems to be made of PVC foam board?   I would like to know how strong it is.
If it's the stuff I'm thinking of, it's supposed to be very strong. I believe it's often used in outdoor signage?
Navigation
Message Index
Previous page
Go to full version
