Author Topic: Scratch Slim Marvel vs Capcom [14 Nov - Finished]  (Read 148808 times)
MrChucky
  • Last login:December 28, 2024, 11:18:08 am
Re: Scratch Slim Marvel vs Capcom [14 Nov - Finished]
« Reply #200 on: September 20, 2012, 01:14:12 pm »
Hi Martijn,
You have laminated both sides of the side panels, I wanted to do this as well with 0,9 mm HPL you used but the 19mm T-molding doesn't flush entirely ( 18mm MDF + 2 x 0,9 mm = 19,8 mm ) , so 0,4 mm sticks out on both sides. How does this look on your Cab ?
And where did you get the perforated plate for the backside panel ?
I'm making a combination of your curved Streetfighter cab and the slim Marvel vs Capcom, work is still in progress I'll make a new Project Anouncement soon with photo's.
Martijn
  • Akira!
    • ModMyBox
« Reply #201 on: October 30, 2012, 04:24:31 am »
Sold  :applaud:
edekoning
« Reply #202 on: October 30, 2012, 05:02:50 am »
So when will you start building a new one :P
« Reply #203 on: October 30, 2012, 10:19:52 am »
steinar-t
  • Last login:April 21, 2019, 02:31:15 pm
« Reply #204 on: November 16, 2012, 04:32:17 am »
Hello Martijn!
Just found this forum a few day ago and decided to make me a cabinet. I really like everything you did on this project :notworthy:
Woud it be possible to get some measurments of your side panels? I want that shape of it!
Got 2 sheets of mdf today :cheers:
Greetings from norway.
Steinar.
VictorBangle
  • Last login:December 30, 2012, 04:27:51 pm
« Reply #205 on: December 07, 2012, 12:04:03 am »
Congrats on a very professional cabinet. Looks simply awesome!
griffindodd
  • Builds Stuff
« Reply #206 on: December 07, 2012, 05:02:24 pm »
Just wanted to say thanks for this build thread, it's responsible for all of my inspiration to build my Revolution cab and also for the credit card bill that build generated.  :lol
Well played Sir!!!!
I drink and I know things.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #207 on: January 16, 2013, 09:27:48 am »
Wow, I somehow missed this build until now.  What a fantastic job start to finish!
otsep
  • Last login:September 28, 2025, 02:53:45 pm
  • I'm your huckleberry...
« Reply #208 on: February 09, 2013, 12:04:58 pm »
Hello Martijn!
Steinar.
Second this. Any Guidance would be great.
Vids: Namco Rockin' Bowl-O-Rama
Pins: Aerosmith Pro, ST Premium Vault, Beatles Gold
Remember Wheaton's Law
jaysaugus
  • Newbie
  • Last login:February 21, 2021, 11:46:56 am
« Reply #209 on: November 11, 2013, 07:38:13 pm »
Hello Martijn!
Steinar.
AGREED!!!  I just signed up for this site just so I could write on this forum in the hopes of getting a blue print or design for this exact cab!
Fursphere
  • Last login:Today at 12:14:39 am
« Reply #210 on: November 18, 2013, 09:51:28 am »
I was personally just wondering how wide it is.  :)
Lewion
  • Newbie
  • Last login:December 12, 2013, 02:30:14 am
« Reply #211 on: December 11, 2013, 03:46:45 pm »
Hello Martijn!
Steinar.
Well, I actually just registered for the same reason. I'm starting to build my arcade this weekend and I would be honored to make one with the same dimensions as this one..
Rob Black
  • Last login:June 01, 2015, 09:38:31 pm
« Reply #212 on: December 11, 2013, 08:00:06 pm »
Hello Martijn!
Steinar.
Me three!!!!! Awesome cab
d3adv3nom
  • Last login:January 15, 2015, 10:58:23 am
« Reply #213 on: January 12, 2015, 03:08:04 pm »
Sold  :applaud:
Hi Martijn
can you please send me the measurements you use to build this cabinet.  so far I like your design the most.
thank you
phoenixtom
  • Last login:February 26, 2015, 03:15:48 am
  • Learning....
« Reply #214 on: February 24, 2015, 04:43:45 am »
Great Cabinet!! Very inspiring!
nanoflower
  • Last login:February 15, 2025, 08:43:21 am
  • All Your Base Are Belong To Us
Re: Scratch Slim Marvel vs Capcom [7 Aug - Plexi Plexi]
« Reply #215 on: May 19, 2015, 03:16:56 pm »
(...)Then started to make the cables for the street fighter fight pad, i extended the switch for analog to digital switch (pad,L-stick,R-stick)(...)
Hi Martijn
I know it's been a while since you build this thing, but I was hoping you'd still be able to answer a few questions about the 3-way position switch on the MadCatz PCB:
Looking at the fitted switch on the PCB it has 6 solder points, yet you only seem to have soldered 4 wires on to yours.
Do you remember:
- if you removed the small pre-fitted switch?
- what solder points you used? (top row, bottom row...?)
- and where you got the replacement switch? (I know it's a long shot ???)
/Nano
« Last Edit: June 04, 2015, 04:25:28 pm by nanoflower »
Martijn
  • Akira!
    • ModMyBox
« Reply #216 on: May 25, 2015, 04:23:36 am »
You can just read out with a multimeter. center is neutral(ground?), one set of pins is not used. and I think connecting left with center or right with center gives away the other 2 modes..
nanoflower
« Reply #217 on: May 25, 2015, 08:10:26 am »
Thank you for your reply Martijn.
I measured the pins as you suggested, and this is the diagram in case any one else is interested.
A 3-position 2P3T ON/ON/ON slide switch is what's needed.
/nano
vaderag
  • Last login:May 07, 2025, 11:33:07 am
  • Building my own cab :)
« Reply #218 on: November 27, 2015, 10:44:49 am »
Hey mate, love this build!
looks way better quality than what I end up building, but anyway I'm wondering about using a 32" tv in my build but wondering how you feel this works with the position you end up standing - i'm worried it may be too big a screen too close? What do you feel?
GamecockMameCab
  • Last login:July 18, 2016, 01:29:48 pm
« Reply #219 on: February 11, 2016, 03:53:11 pm »
Martijn - do you still have the file that is your control panel layout?  I am starting a cab that will be very similar in size and layout, and I love your control panel layout.
nanoflower
« Reply #220 on: March 18, 2016, 08:16:23 am »
Hi
+1 for the CPO laypot, It'd be very helpful. Also how did you fasten the CPO?
/Nano
Martijn
  • Akira!
    • ModMyBox
« Reply #221 on: June 30, 2016, 03:27:34 pm »
Patent has worn out :)
Template : http://www.mediafire.com/download/fw896m7tsn9axi9/control_panel_template.psd
Sketchup model, well sort of. I used sketchup more to design the sides. The inside panels could have wrong measurements!
http://www.mediafire.com/download/1as33c3oqb4sp6q/cabfinal-angled.skp
http://www.mediafire.com/download/73dcebc7lc6o316/cabfinal-angled.skb
« Last Edit: June 30, 2016, 03:31:45 pm by Martijn »
nanoflower
Re: Scratch Slim Marvel vs Capcom [5 Okt - Pcb Pets]
« Reply #222 on: April 07, 2017, 02:19:21 pm »
(...)Mounted the JLF plates(...)
I was wondering about this way of mounting the brackets.
Does it not create a gap that is only covered by the cp overlay, that someone could poke a finger through by accident?
/nano (...and yes I've started my build again, how is your new box coming along? ;))
Nigel-James
  • Last login:October 25, 2017, 10:52:09 am
« Reply #223 on: April 09, 2017, 07:08:38 pm »
Use plexiglass over the top of the control panel.
Martijn
  • Akira!
    • ModMyBox
« Reply #224 on: April 10, 2017, 02:25:33 pm »
the top is covered with laminate, nd the cp art. Good to see you back
nanoflower
« Reply #225 on: April 11, 2017, 08:27:13 am »
Note to self...Why the heck would you want to router anything else out other that the actual shaft hole -not sure what i was thinking  :banghead:.
/nano
connorlo
  • Last login:June 20, 2019, 10:55:46 pm
« Reply #226 on: June 06, 2017, 12:06:07 am »
Hi Martijn,
fantastic build, your posts have helped me alot when building my own cabs. Wondering on this slim one, how do you get to the insides, it doesn't look like any of your panels have a hinge/lock do you have to undo some screws to get in?
Connor
TheRealSkywalker
  • Last login:August 25, 2017, 03:12:56 pm
« Reply #227 on: August 19, 2017, 02:46:10 pm »
Everything looks great! Plan on starting a build just like it any blueprints would be great.
Demon-Seed
    • DemonCade (WORKING URL!)
« Reply #228 on: August 21, 2017, 08:02:59 pm »
Hey
Is there plans/cutouts for this?
csamain
  • Last login:January 07, 2019, 09:55:58 pm
« Reply #229 on: December 10, 2018, 08:40:01 pm »
Hello Martijn!
You did a great job with this cabinet, I love it!
I would love to make one for myself, could you share me the plans or the .psd file containing the theme?
This would give me a good base to start ... You may have already shared them because I saw someone selling a second hand in Belgium but if so, I found nothing ...
Regards
Why?
Why did i sell my old cab?
I miss throwing coins in her , that sound is priceless.  But she had flaws, i didn't like the u360 and her size was just to big.
It needs to be living room proof! And i miss HD gfx games and remakes of old games. the TV didn't cut it.
Replacing it with a LCD would kill her. So she is happy at a new owner now.
After almost 3 years i decided i want a new one. Slim sized, Arcade feel, LCD screen.
LCD with the scan line modes in Mame + tinted plexi and a few beers would fool me anyway  ;)
My holiday is coming and i have some time to spend on it.
I got some sketches on paper, already drew it out in sketch-up and got most of the artwork ideas and design going.
My new one will be similar to my old one, just half its dept. This time no Street Fighter Arcade theme.
But going for the Marvel vs Capcom theme. Based on the latest version 3 characters
Some basic info
Screen : LG 32" 32LD320
Sound : 5.1 Cambridge DTT3500 Digital Black Logitech Z-2300
System : Playstation 3 Slim with large hdd Custom firmware 3.55 Jtagged Xbox 360
Storage : 2 TB Samsung hdd 5400 RPM SATA 32MB
Sticks : 2 x Sanwa JLF-TP-8YT
I have been buying parts and indexing my old parts, materials and tools.
Found a place where i could work , my balcony is a no go this time..
Just my heads up  :laugh:
Drnick
  • Plodding Through Life
« Reply #230 on: December 11, 2018, 02:27:11 am »
Hello Martijn!
Regards
See about 9 posts up for links to sketchup/psd files.
nanoflower
« Reply #231 on: December 11, 2018, 06:38:31 pm »
Hi
You should consider using 16mm MDF instead and a 7mm laminate as well
11/16" T-Molding (17.46mm) will fit. You also need to take the artwork thickness into account when routering the the slot, as this will add the the over all thickness as well.
Hi Martijn,
