Main > Main Forum
so i want to use these speakers in my arcade cabinet
Pages: << < (3/3)
clickhea:
problem is i need the speakers because its a vewlix clone
paulscade:
That will work.  I used the same setup for my cab... Sony auto speakers:
http://forum.arcadecontrols.com/index.php?topic=82241.msg875391#msg875391
http://forum.arcadecontrols.com/index.php?topic=82241.msg875409#msg875409
and a Pyle Amp (attached).
I know that it's overkill... and I probably spent too much... but the cabinet sounds pretty darn good.
I was concerned about the shielding... but I haven't seen any problems at all having the speakers mounted just over the CRT.
clickhea:
nice paul exactly what ive been looking for.
how did you hook the amp up to the computer what connector did you use?
paulscade:
Actually...
If you scroll down on this page... I wired the speakers to a terminal block... and used some "patch cords" that I made to wire from the terminal block to the outputs on the amp.
The input to the amp comes from another cable... with a mini-plug on one end (for the sound card) and RCA plugs on the other end (for the input to the amp).
clickhea:
to complicated for me, i have no wiring expierence.. lol need to keep it as simple as possible ;)
Pages: << < (3/3)
Go to full version
