Author Topic: PC won't boot with graphics card installed  (Read 6408 times)
LeedsFan
  • Last login:January 17, 2021, 06:14:23 am
« on: June 19, 2011, 06:29:38 am »
I'm stumped with a problem I'm having with a PC case I recently bought. The case is an E4034 eMachines setup. It uses MSI RC410M motherboard with PCIe graphics slot. The PC works fine with the onboard graphics (Radeon Express 200) but it just will not boot up with a graphics card installed in the PCIe slot. I checked the BIOS to make sure the PCIe slot is being set as primary graphics.
The card I am trying is the Radeon HD5570 as it's the only PCIe card I have available. This is working fine in one of my other projects. But I can't even get a post beep from the PC. I've tried uprating the PSU from the original 300W to a 400W but that has made no difference. I doubted this was the problem anyway as this card is praised on using low power and and runs fine from a 250W PSU in the other project.
When I play Star Wars in Mame with onboard graphics the game runs fine at 100%... until you destroy the Death Star. That sequence dropped the speed to 65%ish and the sound goes all horrible. Then the game goes to the next level and is 100% again. But that explosion sequence spoils things as it runs so glitchy. I just wanted to try this card out to see if it fixed it, but so far no luck.  :banghead:
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
Re: PC won't boot with graphics card installed
« Reply #1 on: June 19, 2011, 11:39:11 am »
If the machine won't boot with the card in, its likely the card is bad. Video cards fail, and its a common situation for the machine to not do anything with a bad one. Check the card in a different machine to verify its condition.
If it runs in a different machine, try cleaning the contacts in the pci-e slot, and be sure if theres a seperate pwr connector on the video card that its used.
LeedsFan
« Reply #2 on: June 19, 2011, 11:57:54 am »
Awww man I've just spent hours looking for solutions to this problem on Google etc.   The card is quite new and works perfectly fine in my other machine. The 5570 doesn't have a separate power connector... it gets all it's power from the PCIe slot. I suppose it's possible that dust got into the PCIe slot. There's been no card installed in there at all because the metal plate was still intact on the back panel for PCIe card. How would you clean out the slot though? I can only blow it out I suppose.
I did read that some later PCIe cards have issues with older MBs that only support PCIe 1.0.  Maybe I'm just unlucky?  I don't wanna buy another card to try this out.
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #3 on: June 19, 2011, 12:23:49 pm »
Keep in mind that MAME relies mostly on CPU power rather than graphics power. So getting a more powerful graphics card won't help. The stuttering issues will remain.
LeedsFan
« Reply #4 on: June 19, 2011, 12:29:42 pm »
I know that really... but the sound stuttering on that Death Star stage is really bad and it doesn't do it on my other systems. I just wanted to try and see if it helped as I have the card already.
« Reply #5 on: June 19, 2011, 02:42:27 pm »
Try editing your mame.ini file.  Change the sound sample rate from 48000 to 22000. That may help.
LeedsFan
« Reply #6 on: June 20, 2011, 01:31:07 am »
Well I decided I'm wasting my time trying to get this card to work with this PC... so I turned to trying to get Star Wars running 100% with the onboard graphics (Radeon Xpress 200).
The problem with the Death Star sllowdown is definitely a graphics issue because I can turn off the sound clompletely in Mame.ini file and it makes no difference. Then I tried changing the graphics drom D3d to DDraw and that did help a lot with the issue. Game does dip a little to about 96% for a second or so but it's OK. Only trouble is on DDraw the game looks ---steaming pile of meadow muffin---. It's all blurred and horrible.   :dunno
jimmy2x2x
« Reply #7 on: June 20, 2011, 01:40:20 am »
What OS are you using and what version of MAME?
You might be able to downgrade to an earlier version of MAME to gain the performance you want.
Corbo
  • Last login:June 24, 2019, 07:49:12 am
  • I've not seen such bravery
    • Minicade - Mini Gauntlet MAME project
« Reply #8 on: June 20, 2011, 04:49:25 am »
Things I would try:
  • Put the video card in another PC or a friends PC, does it work?
    What is the output of the PSU, perhaps you need more juice.  Try unplugging the HD, and any peripherals and try posting with the video card in.
    Is the BIOS set to use the PCI/E slot (it's usually automatic but worth checking)
    With the video card in are there any beep codes at POST?
    Do you have another PCI/E video card you can try on the same motherboard?  Does it work?
    Any BIOS updates available for the motherboard?
    Microwave the videocard for 80 seconds.  This won't fix it, it will just make you feel better.
_____________________
Wizard needs food, badly!
My mini arcade project:  http://minicade.blogspot.com/
Encryptor
  • Trade Count: (+34)
« Reply #9 on: June 20, 2011, 06:04:04 am »
Things I would try:
You obviously misread or didn't read the OP's first post in the thread.
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #10 on: June 20, 2011, 06:13:18 am »
Looks like your motherboard only supports PCI 1.0a:
http://www.msi.com/product/mb/RC410M-F--L--FI--LA.html#?div=Detail
Slots
• One PCI Express x 16 slot. (supports PCI Express Bus specification v1.0a compliant)
• One PCI Express x 1 slot. (supports PCI Express Bus specification v1.0a compliant)
• Two 32-bit v2.2 Master PCI bus slots. (support 3.3v/5v PCI bus interface)
In a review for the 5570 on newegg, someone said this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161342
Other Thoughts: The bus interface is listed as being PCI-E interface version 2.1X16. The card is not backward compatible with PCI-E interface version 1.0A. I ended up removing the card out of another machine and swapping cards around to make everything work. If you are expecting this card to work on older interface formats, you may be disappointed to find that it won't work.
I haven't seen someone else saying this yet though, but I didn't look very long.
« Reply #11 on: June 20, 2011, 07:57:50 am »
Hmmm. I recently had a similar issue with an eSATA card and a Dell Optiplex. Tried it in several machines (all of the same make) and inserting the card would cause the machine to powercycle constantly. It was PCIE, but I'm not sure of the exact specs involved. This is something I hadn't thought to check.
Cynicaster
  • Last login:June 22, 2021, 12:12:55 pm
« Reply #12 on: June 20, 2011, 09:25:53 am »
The PC in my cab runs like crap on D3D, but perfectly fine (for the games I care about) in DDRAW. I'm in the process of configuring a more powerful PC that I bought for my cab, and it seems to run D3D just fine. Thing is, I'd be lying if I said I noticed any difference whatsoever in what the games look like.  I suppose maybe I should do an A/B on Star Wars if the OP is saying there is such a difference.
LeedsFan
« Reply #13 on: June 20, 2011, 04:36:05 pm »
Slots
This guy has hit the nail on the head!  I went to my local experts at CCL today and asked them about this problem. The answer they gave me is basically word for word what Cottmm says here. PCIe cards that are 2.0 or 2.1 compliant probably will not work in older 1.0 compliant only motherboards. Apparently from v.2.0 onwards the slots supply more power to the cards. This obviously means something more modern will try to draw more juice than the slot can provide and hence no boot up.
I ended up buying an old GForce N8400GS from them for about £21 which worked right off the bat. It made no difference to the FPS in Star Wars but it did provide a DVI slot for my Xerox monitor (it has a fixed lead with DVI plug).
On a side note I managed to snag a different PC box today which had a 3200 Sempron processor in it. It's only 1.99 GHz but for some reason it runs Star Wars much, much better than the other Pentium 2.9 GHz box. I can get through the Death Star scene with no sound hiccups and the FPS drops to 95% which you can't notice with the eye anyway.... so for once I'm happy with some progress.  :)
Corbo
« Reply #14 on: June 20, 2011, 04:44:54 pm »
Well done, another problem solved.
I ran into problems with the space the DVI/VGA cable took up and the cable obstructed the rear case fan.  I then discovered on ebay you can buy right angled DVI or VGA adapters, worth keeping in mind if you run into that problem in your mini cabinet.
May the (Ge)force be with you.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #15 on: June 23, 2011, 05:53:43 am »
The Intel should smoke the Sempron. Sounds kitschy. Of course, you could roll back your MAME.
-Banned-
LeedsFan
« Reply #16 on: June 23, 2011, 12:00:41 pm »
I forgot to mention that both machines were running the same version of MameUI v.132.  I need a late version because I must use the slider controls in the TAB menu to reduce the screen size for my latest project. I can't remember which version of Mame that was introduced but I know I have v.124 and it's not available in that.
ark_ader
  • I glow in the dark.
« Reply #17 on: June 23, 2011, 01:46:38 pm »
I'm surprised you can get away with just a 250W PSU and that card.
LeedsFan
« Reply #18 on: June 24, 2011, 01:35:45 am »
The 250W PSU is from a shuttle (a 1U) like this one:
http://linitx.com/product/12301
I'm not an expert on these things but I've been told that those type of PSUs are way more efficient than the standard older type ATX power supplies. Besides, that card has had very good comments in reviews regarding the low power it needs to run.
GameGeezer
  • Last login:July 07, 2011, 04:51:11 am
« Reply #19 on: June 26, 2011, 08:40:51 pm »
If I wasn't off-line for a large part of the week, losing my mind due to a series of my own technical woes (Palm database reconstruction) that I resolved, I would have been able to help here. When I purchased the video card for my Optiplex 755, I made damned sure that it was the correct bus, as PCIe-2+ bus architecture cards won't work in v1 slots, and sometimes, v1 cards don't work in v2 slots.
The notion that a graphics card doesn't improve MAME is nonsense in my experience. I only run classic titles, and even those suffer without D3D9 working. Why?
I use overlays, bezels and artwork; Every time MAME draws a frame without proper Direct3D support (v8 is not very workable, v9 is far better) it has to rely on an on-board GPU which is slower for a number of technical reasons. Try playing 'Asteroids Deluxe' with the overlay, backdrop or artwork and you'll see what I mean. It's very much like playing in slow-motion, which is a complete action-killer. As soon as I dumped a low-end NVidia card into the system and updated DirectX--Bang!--no problems. Every game runs at full speed with any graphics options. Vector emulation becomes far cleaner too, and I can set sprite pre-rendering to 10 with no hitches. Additionally, monitor effects, such as adding raster lines, are snappy and clean. Not that most would care, but the nag screens and game information boxes are crisp and clear (whereas with DirectDraw they tent to be blurry). The video card's GPU also helps to eliminate a great deal of memory bottlenecks in the architecture, so even if the CPU is doing more of the work that the GPU, the GPU's dedicated memory bus helps speed things along for frame drawing.
I did have to modify my card to make it fit, as the Optiplex uses low-profile cards and because those cost more, I picked up a standard card, and removed some things. The SVGA port was on a box-connector lead, so that was stunningly simply..... I was all ready to re-solder it. It's a tight squeeze, but it works flawlessly.
Now the games can handle drawing the sprites/vectors, plus the backdrop, overlay and whatnot every frame, so a dedicated graphics card is the way to go, as is DirectX/Direct3D9.I expect that if you're running a newer title (post-1996 or so), the stand-alone GPU is even more imperative; I only run a couple games after that point... Mostly adult-y 'Qix' clones ('Gals Panic' type games) though, as I despise polygon-based 3-D games.
Thus, if you haven't bought a new card, just be sure to look for one that matches the bus architecture on your system. NewEgg is always a good place for new cards, but you'd be beat off looking for a used one on eBay (bleah) or Classified Advert sites (e.g. Craigslist, etc..) or flea markets. -GG
« Last Edit: June 26, 2011, 08:47:38 pm by GameGeezer »
newmanfamilyvlogs
« Reply #20 on: June 26, 2011, 10:03:41 pm »
The notion is usually in reference to buying high end cards vs low end cards. Sometimes that point isn't articulated well.
I've seen similar performance discrepancies with onboard SIS chips. Going from maxing out neogeo games at 70% to unthrottled at 180% with a cheap agp radeon.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #21 on: June 29, 2011, 07:54:45 pm »
Since the re-write, the artwork and such *has* needed a decent GPU (though not remarkable, depending on your desktop resolution). Basic MAME performance hasn't - until now with HLSL.
-Banned-
GameGeezer
« Reply #22 on: June 30, 2011, 02:34:00 am »
Right. This is why I selected the lowest-end non-brand ATi card that I could get for my configuration, and it works perfectly.
I run in super-high-resolution mode, with bezels, overlays and screen effects. That combination permits very crisp, life-like artwork and with the screen effects the actual game looks quite realistic/accurate despite being on a high-res CRT. -GG
