| Main > Main Forum |
| Mag-Stik & Mag-Stik Plus Differences |
| << < (2/2) |
| captainobvious:
--- Quote from: AndyWarne on June 12, 2011, 12:01:36 pm ---But... if you were to remove the magnet, the stick would not center at all, not sure why you would want to do that. --- End quote --- To achieve the absolute lowest possible actuation pressure. |
| JustMichael:
--- Quote from: captainobvious on June 12, 2011, 12:59:19 pm --- --- Quote from: AndyWarne on June 12, 2011, 12:01:36 pm ---But... if you were to remove the magnet, the stick would not center at all, not sure why you would want to do that. --- End quote --- To achieve the absolute lowest possible actuation pressure. --- End quote --- If the stick doesn't center, wouldn't you have to pull the stick back the other way to make it stop hitting that direction? Playing with a floppy stick doesn't sound like fun... (yes sounds bad but not meant that way) |
| captainobvious:
--- Quote from: JustMichael on June 12, 2011, 04:01:18 pm ---Playing with a floppy stick doesn't sound like fun... (yes sounds bad but not meant that way) --- End quote --- Playing with arthritis isn't fun - period. But I do what I can to limit the pain. Playing with minimum stress on my fingers and hands often requires some sacrifice. In this case it will be having to return the stick to center myself. |
| Gray_Area:
You really don't want to do that. Try Seimitsus. |
| captainobvious:
--- Quote from: Gray_Area on June 16, 2011, 02:38:00 pm ---You really don't want to do that. Try Seimitsus. --- End quote --- Already did. :) Works like a charm. Now I'm just waiting for the 20 gram Zippy's to arrive. The ones the stick came with take 200+ gram to actuate. Amazingly stiff microswitches. |
| Navigation |
| Message Index |
| Previous page |
