Author Topic: Standoffs for acrylic?  (Read 2040 times)
robertsig
  • Last login:June 03, 2018, 07:24:11 am
« on: June 08, 2011, 11:06:42 am »
I need to mount a motherboard on a piece of acrylic and wanted to know if anyone had some suggestions?  The standard metal standoffs screw into an ATX case, so that won't work.  Are there plastic ones available I could glue?
Franco B
Re: Standoffs for acrylic?
« Reply #1 on: June 08, 2011, 11:28:29 am »
Standard PCB mounting feet would probably be the easiest thing to glue to acrylic.
« Reply #2 on: June 08, 2011, 11:30:22 am »
I've done it with zip ties and a ball point pen I cut up.
  • Last login:March 21, 2024, 08:20:28 am
« Reply #3 on: June 08, 2011, 11:37:12 am »
+1 on pcb feet.
Of course if you are looking for a strict, clear plastic look, you could consider using clear rigid pvc tubing, and putting a screw in the center just the same as pcb feet. The kind of tubing that is used in fish tanks.
Still, I would just go with pcb feet.
« Reply #4 on: June 08, 2011, 11:39:44 am »
Yeah there is no need to glue.  Use machine screws/nuts.
« Reply #5 on: June 08, 2011, 11:43:35 am »
Big Box-O-Machine screws = My best friend with these kind of projects.  ;D
Franco B
« Reply #6 on: June 08, 2011, 11:45:40 am »
Depends if you want the bolt heads showing on the other side or not....
I often use acrylic with counterbored holes to make mounts:
robertsig
« Reply #7 on: June 08, 2011, 01:21:30 pm »
I found a way that I think will work.  It's just a mini-itx board, so it should be secure enough.
I'll glue some of these flat plastic standoffs.
http://www.bizsyscon.com/product/OTHER__BSC-STANDOFF__5144.html
bkenobi
« Reply #8 on: June 08, 2011, 01:43:11 pm »
I've found that clips like those are a pain in the arse.  The ones I've used would bend rather then pushing through the hole.  I would personally use a screwed in solution, but I don't see why those standoffs wouldn't work.
eds1275
  • Last login:May 03, 2024, 12:05:34 pm
  • Rock and Roll!
« Reply #9 on: June 09, 2011, 12:40:37 am »
I generally get a little piece of pex pipe from the plumbing area of home depot. Just a toilet supply tube or something for a dollar, gives me about 50 standoffs.
DillonFoulds
« Reply #10 on: June 09, 2011, 01:59:22 am »
If you're looking for something clear, BIC Crystal pen and a fast spinning, slow moving cutting blade (or mitre/chop saw, SLOW MOVING, fine toothed blade). Or you could maybe try a stationary belt sander?
