Main > Everything Else
Arcade Button Light Switches
JustMichael:
Why 2 buttons? Why not one of those buttons you push it to turn on and push it again to turn it off?
lilshawn:
Buttons?! I just screw in the bulb to turn it on and unscrew it to turn it off. XD
SavannahLion:
UL listing is exorbitantly expensive. It takes oodles of cash just to pay the lab. And last time I checked, it takes quite a bit of time if you're not one of the bigger companies.
This is why it's not uncommon to find "high end" audio equipment with no UL tags whatsoever. Many of the cottage manufacturers can ill afford to pay the fees to the lab. Even less so when they need to pay those fees to multiple countries for whatever version of the UL those outside the U.S. use.
I wouldn't normally bat an eye if I have non-UL qualified equipment (I don't recall seeing the UL tag on any arcade cab that I own ??? ) but I would be hesitant to install anything that's not UL listed into something that's intended to be a permanent fixture of my home. Or more accurately, anything that's not going to pass inspection as a permanent fixture in my home. Owning and maintaining a home is aggravating enough, I don't need to have ---steaming pile of meadow muffin--- installed that's going to cause headaches for me down the road.
--- Quote from: JustMichael on June 18, 2011, 08:32:47 pm ---Why 2 buttons? Why not one of those buttons you push it to turn on and push it again to turn it off?
They've been around: Honeywell's Tap-Lite and TouchPlate Genesis and a third more-or-less recent kind involving a bare metal plate. There's even one that's just a straight forward sensor plate that can be hidden behind wall paper or even tile.
To start, there's no real indicator of state other than the light itself. If the light burns out or if the power goes out, then you have no idea what state the circuit is currently in. On a low voltage system like Tap-Lite, that might not be too bad but on a high voltage system... replacement and repair can get kind of ugly. Actually, now that I think about it, finding and replacing a relay might be ugly too.
And some, like the metal touch or sensor plate, people get kind of cute and hide them for some seriously lame reasons. Knew one guy that hid his in the metal work on his kitchen wall. It was annoying trying to find the light switch at 2AM all because I wanted a drink of water.
Not to say they're all bad. For some applications, they work well. I've got one for the closet door. Open the door, the light turns on. Close the door, lights turn off. There's a ball bearing N.O. switch in the door. I love it so much that I would love to get them for all the closets but I can't make heads or tales of who made them and no one at any hardware store knows what I'm talking about. The ball bearing looks almost identical to these ball bearing catches but there's no corresponding catch plate.
--- Quote from: lilshawn on June 18, 2011, 08:52:46 pm ---Buttons?! I just screw in the bulb to turn it on and unscrew it to turn it off. XD
Ugh... As a kid, I have burnt my fingers many times turning off the lights doing that.
MonMotha:
Many (perhaps most) jurisdictions in the USA do not require that electrical devices used within them be UL listed. There are some notable exceptions, such as the City of Chicago, and some of these allow alternate certifications. Contrary to what seems to be fairly common belief, UL is a private entity. Most governments are loathe to give such an entity full and absolute control over what can and cannot be used within their area of control.
UL is also indeed hideously expensive and complex. I've looked into buying their standards in the past, and, even if I ponied up the rather large amount of money to get them, I'm not sure the license agreement would allow me to read them. CSA international offers similar certifications, and they're a lot cheaper. Many product development houses work with CSA to get things working to their certifications, then submit to UL in order to minimize costs.
The UL's tests are generally good, though. You can generally have reasonable confidence that, should a device bear a (legitimate) UL listing, it's probably reasonably safe in normal usage.
The only standards that electrical devices are generally legally required to comply with in the USA are the FCC's requirements for electromagnetic compatibility and the NEC. Certain industries have their own standards they enforce or generally require. Many insurers of commercial or industrial installations may require that all electrical equipment be listed with some suitable testing agency such as UL or CSA. I wouldn't expect to find this in a residential insurance contract, but of course ask your insurer.
Building to UL, CSA, etc. standards is generally a good idea, of course. Egregious mistakes or failing to follow "generally accepted good engineering practice" could land the maker in hot water over liability issues.
SavannahLion:
Thanks, that's why I added the qualifier. I just couldn't remember which alphabet soup entity is required.
