Main > Everything Else
Arcade Button Light Switches
Pages: << < (3/9) > >>
lilshawn:
--- Quote from: Vigo on June 07, 2011, 02:48:39 pm ---
(Don't ask me why it's in the bushes)
it's a current bush.... *cough cough*
*rimshot*
*crickets*
DaOld Man:
Actually, it wouldnt be too hard to make one of those arcade PB light switches.
You would need a blank cover (easy to find), two buttons, and a 120 VAC (or 220 VAC, depending on your houses light voltage)  DPST relay that is small enough to fit in the box.
One drawback would be that if the power blinked the light would stay off.
lilshawn:
can i get someone to check my work... it's to damn early for saturday for me and stuff runs slow amirite?
kalars123:
reply ummm, i wouldn't use a micro-switch as a light-switch I'm pretty sure they aren't rated high enough amperage level. even with the relay, there would be enough juice going though the hot side to melt the micro-switch.
lilshawn:
looks good to me...  :dunno
Go to full version
