Author Topic: Spinner Hack Encoder Wheel  (Read 2096 times)
  • Last login:March 21, 2024, 08:20:28 am
« on: May 27, 2011, 04:23:14 pm »
Hi, I have an old arcade spinner that I want to hack a mouse to use it's optical sensor. My question is on the encoder wheel. Should I use the encoder wheel from the mouse, the old encoder wheel from the spinner, or do I need to make/buy my own?
If I use the mouse encoder wheel, how would I mount the encoder wheel on to the spinner shaft. The mouse encoder wheel looks kinda like this:
If I use the original encoder wheel, I noticed the teeth are much bigger, is that going to mess the optical sensor up?
Re: Spinner Hack Encoder Wheel
« Reply #1 on: May 27, 2011, 04:42:02 pm »
I don't think using the arcade spinner encoder will mess up the optical sensor of the mouse. I'm pretty sure if you used the mouse encoder, it would just make the spinner faster than if you used the arcade encoder. If it were me, I would try it with the arcade encoder wheel first to see how it performs. But I have never done a mouse hack before.
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #2 on: May 27, 2011, 04:47:23 pm »
Could i use this to hack a wingman controller?
BobA
  • What Me Worry?
« Reply #3 on: May 27, 2011, 05:03:03 pm »
Easiest way is to remove the receiver on the mouse board and turf the mouse encoder wheel.  The wires from the spinner attach to where the receiver was removed and to power.  This way there is no fiddling around with the mouse encoder wheel as the spinner encoder wheel is already mounted in the spinner. This is a standard mouse hack for spinner or trackball.
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
« Reply #4 on: May 27, 2011, 05:06:31 pm »
I.1478 posts and you finally posted something funny.  Guess I shouldnt have taken the over.
« Reply #5 on: May 27, 2011, 05:18:42 pm »
Thanks, everybody! Boba, I will take your advice. I thought I had seen examples of mouse encoder wheels being used, but I seemed a bit silly to try to mount the mouse encoder on the spinner. This makes sense to me.
« Reply #6 on: May 27, 2011, 05:20:30 pm »
 :lol Are spinner threads really cursed like you say, or is it that you post things like this on these threads that send them down the crapper.  ;D
Donkbaca
« Reply #7 on: May 27, 2011, 05:38:31 pm »
Oh boy! I never said that.  I sad spinners were cursed, not spinner threads.  Actually I didn't even say that!  I said that spinners bring bad Karma, and not even that is a direct quote! You should at least quote me, instead not only did you misquote me, you made me misquote myself... TWICE!!
 You don't know what you are talking about, in fact, you don't know what you are talking about to such an extreme degree that you have forced me to not even know what I am talking about, and what we were talking about is what I talked about.  Thanks, just thanks, now this all utter nonsense.   You are so abrasive.  I hate you.
THe end
« Reply #8 on: May 27, 2011, 05:41:06 pm »
THe end
:laugh2: :laugh2: ---steaming pile of meadow muffin---, I almost crapped my pants there.  :laugh2:  :laugh2:
Hoopz
« Reply #9 on: May 27, 2011, 06:11:30 pm »
Somebody started the weekend early and has been drinking.  Two funny posts in the same thread.  Donky is on fire.
 :laugh2:
scofthe7seas
  • Last login:January 10, 2012, 11:33:10 am
  • I'm Eskimo. There's nothing here.
« Reply #10 on: May 27, 2011, 10:52:34 pm »
For reals, I read the original topic and thought about posting something VERY similar to what Donk said. But I wasn't going to because I didn't want to stir the pot.
I commend your efforts Donk.
Donkbaca
« Reply #11 on: May 28, 2011, 12:44:00 am »
Thanks :cheers: I do what I can...
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #12 on: June 09, 2011, 09:04:49 pm »
The encoder disc and the slotted opto must match. It just is that way.
