Main > Everything Else
Color/eye test
one2three:
Got a 63 first try. 38 second time around with switching between monitors and adjusting accordingly. I Usually fail the number dot test pretty bad so I didn't expect a great score.
Xiaou2:
heh, this is one reason why you want am artist with good color experience to do things like accurate preservation efforts (pinball art...) ,rather than a person whos not too color savvy, and has little experience with using them.
Im somewhat shocked at the variances in results though. I assumed that may be slight differences... but the range of results is quite vast, all over the map.
Edit: Took the test. Got a Perfect ;D
A little surprised, cause there were a few tones that were really tricky to tell apart.
saint:
Took it again. Three differences from the first time:
1. Monitor at work instead of at home. :dunno
2. New glasses, same prescription mostly but these are cleaner/not scratched :)
3. Took more time, when I was done I did something else then came back for a final look before submitting.
7
Dartful Dodger:
Too bad it doesn't show you your graph highlighting the ones you've missed.
I took it again and after I thoguht I was done I zoomed way in and made more changes.
I got a 4.
I want to know which ones I missed.
Xiaou2:
Zoomings a bit of a cheat. But anyways, it does show you which ones you missed.
Look at saints picture. Theres bars under the colors which are 'off'.
It doesnt tell you the place where they are supposed to go.. but it does show you which ones.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
