Author Topic: Killer Instinct 2 monitor help  (Read 785 times)
postmortem
  • Last login:July 03, 2020, 10:58:40 am
« on: May 25, 2011, 01:29:05 am »
Just got a KI2 machine and the monitor doesnt display blue. I plugged another game into it and it doesnt display blue either. I can turn the blue bias on the neck board up and the screen turns blue so I figure the problem is either the blue wire in the jamma harness or something is wrong with the chassis. There is some white stuff at the base of all the caps on the chassis and I dont know what it is. Could it be something leaking? would a cap kit fix this?
Cabs: Tron, MKII, MK4, KI2, Blitz99, TMNT, Pac-Mania, Defender, Mame Box.
PCBs: MK1, UMK3, Killer Instinct, Area51, Sunset Riders, Pit Fighter, Wargods.
Pins: Bride of PinBot, Attack from Mars, The Shadow
kalars123
  • Last login:August 09, 2019, 12:31:51 pm
Re: Killer Instinct 2 monitor help
« Reply #1 on: May 25, 2011, 01:48:23 am »
is it powdery? those caps are probably poped, i used to go through this alot back in the day OCin pre-500mhz computer's heh
postmortem
« Reply #2 on: May 25, 2011, 01:55:33 am »
its solid. almost like dryed paint
kalars123
« Reply #3 on: May 25, 2011, 02:51:52 am »
mmm not sure what to tell you then, if it was the cap's leaking it would be solid, but abit powdery you could easily scrape it away, but if it's SOLID I've no idea, no harm in a cap kit though, if it's not displaying blue then as the old saying go's you can't brake what's broke.
  • Last login:Yesterday at 09:56:41 pm
« Reply #4 on: May 25, 2011, 08:21:25 am »
if thats like the stuff on my monitor its just to hold the cap in place. I'd check the blue from the jamma wire to the input on the chassis.The plug should be ont he right hand side of the chassis if youre facing the back, and its a dedicated KI2
postmortem
« Reply #5 on: May 25, 2011, 03:16:26 pm »
The blue wire looks good. no cuts or anything, I messed around with it and still no blue. I was recently told that it could be the trasnsistor on the neck board. He said those machines run them really hot and the break often. Any truth to this?
« Reply #6 on: May 25, 2011, 03:30:50 pm »
your best bet is to post this in the monitor section, much smarter people then me there.
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #7 on: May 25, 2011, 03:51:54 pm »
The transistors do get hot and tend to fail, but if that were the case you shouldn't be able to get a blue raster out of it by turning up the drive/bias.
But yes, this needs to be moved to the Monitor forum.
Probably should post more pics of the thing also. Is that a K7000?
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #8 on: May 25, 2011, 04:18:49 pm »
This needs to go to the monitor section (You can also post over @ KLOV's Monitor Section, as they have some real dedicated monitor guys.)
The white stuff is silicone, it's there to stop vibration noise, as some parts switch at audible frequencies, and it's annoying.
If you can turn the screen blue with the bias pot, then you need to follow your JAMMA harness back and check for a break in the blue line. If nothing is wrong there, then you're going to be looking at a chassis problem. Need more pics to be able to tell what sort of monitor you've got there.
MonMotha
« Reply #9 on: May 25, 2011, 08:48:58 pm »
Swap the red and blue video wires from your game board (either at the JAMMA connector or where they plug in to the monitor).  If you now have blue but no red, then you've got a game board or wiring issue.  If the problem remains a lack of blue, then the problem is with the monitor.
And yes, this needs to be moved to the monitor section. Inform a mod.
postmortem
« Reply #10 on: May 25, 2011, 09:54:42 pm »
Thanks for all the help guys.  Its the original monitor for the cabinet. Im not sure the model but I know its the same as my MK4 cab. So I took the neck board off MK4 and put it in KI2 and I have all colors!! So the problem is definately on the neck board. Im gonna take it to the local repair shop to get it fixed. Thanks for everyone's help!
