Author Topic: Odd request.. Anyone know where I might find gold colored arcade push buttons??  (Read 4722 times)
Zeosstud
  • Last login:April 17, 2024, 03:12:48 pm
Hello All,
               I know it is an odd request, but I have built a small bartop cabinet and it has a Mizzou Tigers Theme and I was hoping to locate a few gold buttons.
Thanks,
- Rodney
lilshawn
  • Last login:May 06, 2024, 08:27:40 pm
Zeosstud
I am starting to think that your right, painting the buttons may be my only choice..
Thanks,
Rodney
Checkout Dr. Ventures thread
http://forum.arcadecontrols.com/index.php?topic=88515.40
On page 2, he starts discussing painting pushbuttons
Donkbaca
    • Slim built MAME/Xbox cab
You can always try a LED buttons with an RGB to get the right color lit up...
Blanka
CNC them from aluminium and anodise them in gold.
gaffner
  • Last login:November 05, 2013, 04:55:20 pm
Thanks,
Rodney
I actually decided I wanted gold colored push buttons myself as well.  I had a bunch of red buttons that I had purchased before I completely changed the look of my cab, and I didn't want them to go to waste.  My wife's solution was to spray paint the suckers brass.
I was worried that they wouldn't work right after that, but they almost all came out fine.  There was one that I had to push quite a few times to work out the stickiness of the button, but after that, it was all good.  And, the buttons are pretty cool, I think... Definitely original.   :)
SavannahLion
Easier said than done, especially if no CNC is readily available.
If you come back with a response about access to a CNC which doesn't cost me my first born, let me know. I'm serious about that.
Zeosstud
Thanks,
Rodney
You happen to have any pics of how it all ended up??  I would be curious to see them !!
- Rodney
danny_galaga
  • Last login:Yesterday at 09:08:57 pm
    • dans cocktail lounge
lilshawn
  • Last login:March 21, 2024, 08:20:28 am
I was wondering the same thing.  :lol
Those look like the wico leaf style buttons. Do you think any old leaf holder would fit on that?
Here is one that Bob Roberts Sells.
danny_galaga
Dupli-Color chrome spray paint??
http://duplicolor.com/products/automotiveMetallic/
 :whap
okay danny, where's your link to gold colored push buttons then? hmm?
Don't need one. It's absolutely pointless painting buttons. Just don't do it...
Gray_Area
  • -Banned-
  • -Banned-
Has anyone considered getting buttons made from an online 3D printing place, or some place like Shapeways?
-Banned-
  • Last login:Yesterday at 03:22:36 pm
You can get Seimitsu buttons with a clear plunger and add 18k gold foil to the inside of the plunger.
GameGeezer
  • Last login:July 07, 2011, 04:51:11 am
I suggest SEM paint, which is a dye-like paint meant for hard-plastic automotive interior parts. I recall it in a variety of goldish tones, and you can have it mixed to order for airbrush use if you want something custom, or simply buy the offf-the-shelf spray colours. It will last a very long time and doesn't scratch off (at least not without effort) as it forms a quasi-molecular bond to the plastic. It works on hard, semi-hard and soft plastics: I've used it on buttons, case shells for games and consoles, vinyl and rubber...
You can also use oil/candle dye on very soft plastics, which you can pick up at craft stores. This can be handy for colour-coding wires without buying giant reels of multi-colour-cased stranded or solid-core copper wire, which costs a fortune now-a-days. -GG
Donkbaca
or get clear buttons and paint the inside of the plunger
Jack Burton
  • Last login:August 26, 2023, 11:32:31 pm
Probably way out of what you're looking for but there are these here:
http://www.aliexpress.com/product-gs/377376114-Anti-vandal-Pushbutton-switch-V19-golden-plated-silver-contact-IP67-CE-Certified-wholesalers.html
and here:
http://cnhiwell.en.alibaba.com/product/402052899-209880379/Brass_gold_plated_anti_vandal_metal_pushbutton_switch.html
Only 19mm though.  But they would probaby be alright for a bartop like you're making.
Some of the other buttons featured on that site have the option for gold plating.
According to the website they can be set to have the plungers stick up a bit over the lip like an arcade push button does.
No clue about the quality of these.  I'd venture that they have quite a bit more resistance when being pushed down compared to a standard arcade button.  I think the switch will screw out of the body of the button and you can replace it with one that needs less pressure to engage.
« Last Edit: June 14, 2011, 05:05:07 pm by Jack Burton »
GameGeezer
Granted, those look amazing, but I have to worry that a brass button may have a few issues: Its weight may make rapid button hits problematic, plus the button seems rather flush with the ring, which may itself be problematic. Certainly bad for shooters where rapid button slamming is needed... If the button was raised another 1/4" or so, that wouldn't be so bad, but it looks like it will require more persuasion during plan that one may want. Obviously, if the spring used isn't powerful enough, then it will also have slow return. They will also be prone to corrosion in humid environments. -GG
Jack Burton
If you'll follow the second link you'll see there is an option when ordering to have the actuator (plunger) in a "high" or "domed" configuration.  I think one of those will be more conductive to arcade games.
As for brass making the button sort of sluggish to respond, you might be right about that.
« Last Edit: June 15, 2011, 11:19:07 pm by Jack Burton »
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
Them expensive bastages from "pinball life" are the way ta go. Leaf sw only tho....
