Author Topic: Which version of mame to use on old computer  (Read 1979 times)
ramsanus2000
  • Last login:August 21, 2011, 03:59:35 pm
« on: May 24, 2011, 11:25:46 am »
I fried my good computer (don't ask) :banghead: that I was using in my cabinet.  Until I can afford a new one, I want to use an old computer I have on hand.  It's a 900mhtz.  I'm using mala and mame v0.126 but it's super slow.  I will continue to use mala.  I also have full rom sets for mame v0.36 and v0.84.  Which one do you think I should use?  I know neither of them will support the high scores.dat.  Will either of them support the command line -no nag?  Do I need to compile?  Any suggestions?
Donkbaca
    • Slim built MAME/Xbox cab
Re: Which version of mame to use on old computer
« Reply #1 on: May 24, 2011, 11:51:48 am »
I suggest you shell out 100 bucks and get a core 2 or better.
« Reply #2 on: May 24, 2011, 12:49:37 pm »
What style of games are you playing? If it's older vertical style games, the 900mhz will be fine if you run a much older version of Mame. If it's games from the 90's - you'll want a better machine.
ark_ader
  • I glow in the dark.
« Reply #3 on: May 24, 2011, 12:51:31 pm »
.84
ramsanus2000
« Reply #4 on: May 24, 2011, 12:59:21 pm »
80's classics.  Anyone know if the command line -no nag will work on 0.84?
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« Reply #5 on: May 24, 2011, 01:09:15 pm »
I still have one or two  900MHz laying around for kicks, but people are throwing out P4's all the time- I found 5 or 6 going in the trash or at the curb over the last year. But anything <V.099 should work ok.  You have to use win98 or a stripped down xp for the best results too.
mgb
  • Last login:February 21, 2024, 06:18:13 pm
  • North East, US
« Reply #6 on: May 24, 2011, 10:49:17 pm »
I was running v.090 on a p4 @ 900mhz.
It ran all of the classics from the 80's great and I also ran the fighters and Neo Geos without issue. The audio was a little choppy on Golden Tee but it played well enough.
