Author Topic: Best control panel set up for cabinet  (Read 3781 times)
mytymaus007
« on: May 21, 2011, 09:03:11 pm »
Im building a caberet with hot swap panels. Whats the best joystick and button setup for all console's old and new. I will have usb ports for the games that are better for a gamepad but is it possible to play all consoles through the control panel and not even bother with a game pad at all.
mytymaus007
Re: Best control panel set up for cabinet
« Reply #1 on: May 22, 2011, 12:10:32 am »
What consoles are people playing in their cabs that would work with a control panel instead of a gamepad :banghead:
scofthe7seas
  • Last login:January 10, 2012, 11:33:10 am
  • I'm Eskimo. There's nothing here.
« Reply #2 on: May 22, 2011, 01:13:46 am »
I don't play consoles on my cabinet, but I would imagine Genesis games would work really well.. probably SNES and NES also.. maybe some older non analog PSX games.
Corbo
  • Last login:June 24, 2019, 07:49:12 am
  • I've not seen such bravery
    • Minicade - Mini Gauntlet MAME project
« Reply #3 on: May 22, 2011, 04:23:14 am »
TurboGrafix works well with a 2 or 6 button layout.
Any console that doesn't use an analogue stick
I'd like to give the CD32 a whirl I think that might work well.
_____________________
Wizard needs food, badly!
My mini arcade project:  http://minicade.blogspot.com/
DirtyDachshunds
    • First Project: MillerCade
« Reply #4 on: May 23, 2011, 09:27:15 am »
I play console games through my control panel, although it's drawn some criticism for my amount of buttons.  All NES, SNES, and genesis games play great (re-beat "A link to the past" not too long ago using my CP).
Even some analog games work great if you have a U360.  I've played Zelda: Ocarina of Time on my CP and the U360 worked great for my analog controls with my buttons.  However there is no easy way to play any dual-analog games (shooters) without a controller.
« Reply #5 on: May 23, 2011, 10:03:57 am »
I guess I never really understood why people are playing console games on their arcade games. It seems to me that if someone cared enough about authenticity enough to have a full sized arcade cabinet, they would prefer the authentic feel for console games as well.
i.e. a bag of chips, a 2 liter of soda, controller, sitting on a couch, and tv.
scofthe7seas
« Reply #6 on: May 23, 2011, 10:56:54 am »
I suppose you can think of it as a kind of "Play Choice" expansion.. Though I've never been a fan of the playchoice systems.
Corbo
« Reply #7 on: May 23, 2011, 11:01:46 am »
Console games are a great addition to an arcade for when you want a little more depth.  Arcade games are designed to give you a quick blast of fun and take your money.  Console games can be played out over a period of weeks with save states.  Sometimes I want a blast of Outrun, other times I want to get a few stages further on ToeJam and Earl and save my game.
Console arcade ports however, I find them pretty pointless when I can fire up the real arcade version of a game!
« Reply #8 on: May 23, 2011, 11:09:23 am »
thats my point...
I'll sit on the couch for a few weeks vs standing at a arcade game. The only practical way I see it making sense is to save space, but to me, it's too much of a compromise.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #9 on: May 23, 2011, 11:20:49 am »
Other than Ape Escape, I can't think of any games that required analog. Usually it was just optional.
mytymaus007
« Reply #10 on: May 23, 2011, 11:21:06 am »
I see your point but since Ive been using Hyperspin im addicted to adding more systems to my wheel. So im not 100% authentic when it comes to consoles.
DirtyDachshunds
« Reply #11 on: May 23, 2011, 11:26:31 am »
It's more for nostalgia.  A lot of these arcade games bring back these nostalgic memories I had and I wanted to capture that with consoles in my arcade as well.  Also, I love having the ability to play The Simpsons or something with friends then switch over to the original Tecmo Super Bowl.
Also, I don't want 10 systems setup under my TV for the 'authentic feel'
mytymaus007
« Reply #12 on: May 23, 2011, 11:30:44 am »
I checked out your CAB looks great. As for the 8 button setup im asssuming thats used for your console games. So if you had to build your cab again would you use the 8 button setup. Im thinking that 8 buttons with a u360 might cover most console games. This is the reason why i went with hot swap panels so i can add on as needed.!
DirtyDachshunds
« Reply #13 on: May 23, 2011, 11:47:00 am »
It definitely covers all consoles if you use P1 start as Start and a coin button as 'select'.  For what I wanted out of my cab, I wouldn't change anything.  I'm one of the few who like the larger sized cabs, and grew up playing 4 player games with strangers like the simpsons or x-men.
I laid out all my controls, and it didn't look overly crowded (which can be argued), so I figured why not?
However, I rarely use all 8 buttons and I play MAME games more than any other, but I do play other games occasionally and like having the functionality to be able to play those games.  Also, I have never had player 2 use all 8 buttons yet.  A multi-player game that uses all 8 buttons requires serious commitment to learn the game from the second party (which my arcade is generally used for shorter play sessions with guests).  But I needed the 8 buttons for player 2 for symmetry.
And I could of went down to 4 buttons for P3 and P4 instead of 6.  I was thinking it would be fun to play something like 4 player madden or something, so I went with the 6 buttons for P3 and P4, but they haven't been used yet.  But then again, I do have the functionality.
« Reply #14 on: May 23, 2011, 11:47:44 am »
I guess I don't care so much about using an actual console. The way I did it was to mod my original Xbox to play all the older console games.
Corbo
« Reply #15 on: May 24, 2011, 03:39:12 am »
thats my point...
Buy a stool lol.  It doesn't affect me so much, my mini arcade has HDMI out and USB.  So I can plug it into the TV and sit back on the couch with a control pad :)
