Main > Main Forum
Best way to convert a HotRod SE to USB?
Donkbaca:
Its a serial connection. It plugs into a USB cable that is included. THe other PS2 is for connecting a keyboard to program the different modes. you can just ignore it...
BobA:
Stripped off the connectors on the Hotrod wires and connected directly to the controller terminal board. You just have to refer to the attached documentation and connect your buttons accordingly.
Guywiththegun:
--- Quote from: Donkbaca ---Its a serial connection. It plugs into a USB cable that is included. THe other PS2 is for connecting a keyboard to program the different modes. you can just ignore it...
Thanks, looks great then.
--- Quote from: BobA ---Stripped off the connectors on the Hotrod wires and connected directly to the controller terminal board. You just have to refer to the attached documentation and connect your buttons accordingly.
Maybe a dumber question than the VGA thing, but what would I need to strip the connectors off?
BobA:
Just cut the wires at the connector with a side cutter and strip the wire to use it with the screw connector on the ipac.
mark shaker:
http://www.xgaming.com/store/arcade-parts-and-accessories/product/hanaho-hotrod-joystick-upgrade-kit/
- Mark
