Main > Everything Else
Under my deck
<< < (2/2)
Necro:
Whoever did your siding/gutter - have them wrap them in the same material.
Donkey_Kong:
I would probably just paint those. If you do I recommend Kilz Oil base Primer and then top coat it with something like white latex paint to match those stair railings.
Second thought: The white might not look good there but maybe your house trim color, or something?
Necro:
That was my thought DK - just get some vinyl clad aluminum, same color, wrapped around them.  Done.
I think the railings are plastic/vinyl anyway, so would match or could do that color.
Howard_Casto:
If that isn't what you are looking for your local building supplier should have a variety of columns you can get.  They are typically hollow and made out of aluminum or vinyl and made to fit around a standard square post.  And before you ask, they are seamed so you can wrap them around the post without having to remove it first.
Navigation
[0] Message Index
[*] Previous page
Go to full version
