Main > Project Announcements
Finally after 10 years!
leapinlew:
You may want to address the lighting issue of your marquee area. The brace needs to be trimmed back to allow the light to cover the entire marquee. If you don't do this, you will have 4 dark square areas in each corner of the marquee.
newmanfamilyvlogs:
--- Quote from: leapinlew on May 25, 2011, 11:15:36 am ---You may want to address the lighting issue of your marquee area. The brace needs to be trimmed back to allow the light to cover the entire marquee. If you don't do this, you will have 4 dark square areas in each corner of the marquee.
+1
Here's an example of the issue and how someone fixed it:
http://forum.arcadecontrols.com/index.php?topic=98284.0
Better to take of this now than after you've got the whole thing painted!
Woodshop Flunky:
Nice to have a helper small enough to fit inside the cab! :)
BobA:
Here is another way to fix the problem. Totally dependent on the marquee you choose.
Indyplumber:
I thought I had auto notify on for this thread. Otherwise, I would have known of your warning for the black squares. Here are some updates on the cab.
I went with a basic MAME theme for now as my daughter and I were fighting over naming rights. ;D
We finally decided to wait and see what kind of nicknames folks come up with that stop by to play.
As for the squares behind the marquee, you'll see I just found that out today. Doh! But never fear, the dremel is near!
