Main > Project Announcements
pocket change- Rain, Hospital, and work
Donkbaca:
You shoul get one if those coin mechs that accepts all coins for your coin door, then you could coin up with any pocket change you have
AurorasDady:
have to look into it. may be a good place for saving up my change.
Stupid noob question warning. I see other posts where in they are able to type then place a picture, type the place picture and so on, I was wondering how to do this as to make my posts less confusing?
drventure:
It's a pain. There's a thread in Project announcements called "Thread for images" or something like that.
You go there, add a new message with "something" in the message body, then attach your images to that message.
Save the message.
Then go back to it and copy the links from the images that are attached.
Then, go back to the thread you REALLY want to post to, start you post, copy the link to the image into the post, and then surround it with
open-square-bracket IMG close-square-bracket {your image path name here, dropping the curly brackets} open-square-bracket /IMG close-square-bracket
I can't actually put those codes in because the board will replace them.
Hopefully, that makes sense....
sapro:
Testing, you can usually use the code tags to insert preformatted text
--- Code: ---Put your description of your first image here
[img]http://www.urlforyourphoto.com/pic1.jpg[/img]
Then talk about your next image
[img]http://www.urlforyourphoto.com/pic2.jpg[/img]
--- End code ---
That should help...
AurorasDady:
yeeeeah...
I'm thinkin, I will just write in this format
blah blah blah :blah: see first pic
blah blah bla :blah: see second pic
:banghead:
thanks for the help though , guess I could try it
