Author Topic: Question about Donkey Kong rivet screen  (Read 2219 times)
LeedsFan
  • Last login:January 17, 2021, 06:14:23 am
« on: May 13, 2011, 05:40:50 pm »
I've noticed on my projects that sometimes on the rivets screen there seems to be a "problem" and I'm not sure what causes it. In fact I'm not sure even if the original arcade game does this because i don't have access to one to check.
Basically I get into the "taunt" position on the top level (to the right) near DK and jump while moving the sick to the right while in mid-air to get 100 points for each jump. But sometimes while I'm doing this Mario edges a little to the right. He doesn't do this on every jump. But sometimes more than others. So much so that sometimes he even turns around to face to the right and eventually moves out of range of the 100 point gain. Has anyone else noticed this? What causes this? Does the original arcade game exhibit the same behaviour?
Sometimes I can play a game where it doesn't do this at all.   :dunno
Bender
Re: Question about Donkey Kong rivet screen
« Reply #1 on: May 13, 2011, 07:38:37 pm »
no it shouldn't do that check the deadzone # for the joystick and up it a bit see if that helps
Paul Olson
  • Last login:Yesterday at 03:19:08 pm
    • Paul's Arcade
« Reply #2 on: May 13, 2011, 07:42:30 pm »
My guess would be that you are hitting right just a hair early and causing the movement.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #3 on: May 13, 2011, 09:25:47 pm »
Ditto. By the way, you can jump either direction, regardless which side of Kong you're on. Of course, you want to jump away from him, in case you flub.
-Banned-
LeedsFan
« Reply #4 on: May 14, 2011, 02:01:51 am »
Hmmmm.... but if I hit right early then surely Mario would actually jump right and not straight up. I will try Bender's idea, but I'm not sure what the deadzone setting should be. I've never played around with that setting.
Bender
« Reply #5 on: May 14, 2011, 10:38:34 am »
I think the mame default is 25% I'd try 35% to start with and fine tune it from there
your not using a U360 by any chance are you?
CrazyKongFan
  • Last login:June 06, 2017, 01:22:29 pm
« Reply #6 on: May 14, 2011, 11:08:30 am »
Maybe you're holding the joystick down too long and moving after you land?
Bender
« Reply #7 on: May 14, 2011, 11:39:17 am »
humm...  that is a possibility, never had it happen to me, but just tried it and it can happen if you push too long on the joystick
just tap in a direction at the peak of his jump and don't hold
LeedsFan
« Reply #8 on: May 14, 2011, 02:07:34 pm »
No. It does it either with XBox 360 pad or Seimitsu LS32.... on two different machines.
EDIT:   I just tried Bender's idea on my desktop PC whicj just uses an XBox 360 pad and Mame-UI.  It worked! Well... I played a quick couple of games of DK and reached L=05 and it didn't do it once. The default setting in Mame-UI was 30% so I upped it to 50%. Everything played just the same as before except that little annoyance was gone. I'm gonna leave it at 50% and try that setting on my other projects and see how they go.
Thanks Bender   :cheers:
Bender
« Reply #9 on: May 14, 2011, 03:07:32 pm »
No problem, I've had similar issues with analog sticks like the Xbox360 controller, but....
Man, that's wierd that it would do it on micro switch stick (Seimitsu) my understanding is that it's just for analog, but hey, if it works
on that machine I'd make sure mame wasn't trying to put an analog map on that digital stick :dunno
under mapping it defaults to "auto" which I might turn off for a digital stick, although I guess that brings up issues between 4-way and 8-way
read this from line 854-930
« Last Edit: May 14, 2011, 03:10:58 pm by Bender »
