Main > Main Forum
Probably a stupid question but.....
Pages: << < (3/3)
Donkbaca:
Why do you want a PS3 and a 360?  Most games are cross platform, and most console exclusive games you would probably want to play with a d-pad.
Anyhow if you want to do it do this:
http://www.slagcoin.com/joystick/pcb_wiring.html
look at the bottom of the page.  Basically you solder, say the up contact on the XB 360 to the up contact on the ps3 and then you connect the PS3 to your controls.
DataWest:
Haha no it's not a stupid question. Basically it comes down to the fact that everyone I know has a ps3 only. Getting the games for it is much easier for me.
Ok I'm confused. Isn't the bottom of that page for a ps1 controller to a 360 controller? I'm going to be new at soldering, does anyone have a more detailed diagram of that process?
Donkbaca:
yeah, it is, but it would be the same basic concept.  I am sure if you search the shoryuken forums you will find more detail.
So why not ditch the 360 and just use a hacked PS3 controller hooked up to a KVM?
DataWest:
I could just ditch the 360.
I know they make drivers for windows that allow full functionality of the PS3 controllers. I'm confused as far as the use of the KVM
Any particular brand of PS3 controller that would be easier to hack?
Donkbaca:
I can walk you through the KVM thing.  Are you using a monitor with a vga input?
You need a ps3 to vga adapter and a female to female vga adapter, a rca to 3.5 mm adapter, a female to female 3.5 mm adapter and i would suggest the belkin kvm I am using.
I am sure there are ps3 hacks on the hsoryuken site.
Pages: << < (3/3)
Go to full version
