Author Topic: Help with my 2nd CP  (Read 1463 times)
rcub3
  • Last login:May 31, 2017, 04:56:23 pm
Help with my 2nd CP
« on: May 10, 2011, 11:15:04 pm »
My MAME cab will have swappable CP's.  I have everything I want for my main CP (essentially 4 joysticks and buttons for 4 p games, but making sure it works well for fighters too).
My second CP will be the frankenpanel for games that use everything that is not a regular joystick.  I want to have a spinner and tron stick, and a trackball.  My question:  how many pushbuttons should I use, and where should I put them?  I'm guessing that something like a triangular layout would be best:
SPINNER          TRON
        TRACKBALL
Maybe a pair of buttons between the spinner and the tron stick?  and maybe to the right of the Trackball?  How many?
As an aside, anything else that I should include? rotating stick?
Paul Olson
  • Last login:Yesterday at 03:19:08 pm
    • Paul's Arcade
Re: Help with my 2nd CP
« Reply #1 on: May 11, 2011, 01:36:55 pm »
Since you are using swappable panels, why are you trying to add everything to one panel? I think you would enjoy trackball games much more if you make a dedicated panel for it. That was you won't have to worry about hitting any other controls.
  • Last login:March 21, 2024, 08:20:28 am
« Reply #2 on: May 11, 2011, 01:53:18 pm »
My guess here is because he really has a larger area to work with...he is only using swappable Control panels to avoid the mothership sized frankenpanel, and probably doesn't want 5 customized control panels lying around at the same time. To me, a trackball, tron stick and a couple spinners doesn't seem too cluttered for one control panel.
rcub3: I don't know exactly how many buttons you would want for this, but are you planning on using your spinners for racing games as well? That would possibly dynamically what you would need on the panel.
alfonzotan
  • Last login:November 28, 2023, 08:39:45 am
    • The Cab With No Name
« Reply #3 on: May 11, 2011, 02:26:24 pm »
Oh, no, I'm not falling for this again.  It all starts out innocently with control panel talk, and the next thing you know, the thread is all full of Big Toe Poke Of Death instructions from the Hong Kong Book Of Kung-Fu...
rcub3
« Reply #4 on: May 11, 2011, 02:30:26 pm »
Yes, I don't really care much for how that second panel will look.  But the main one that will be on the cab most of the time should be as "clean" as possible, IMO.  Maybe I could add the trackball to the main cp, but I already invested in one optipac....
Re Spinner: Sure, I could do racing games, but it would be mainly for games like Arkanoid, and whichever other good classics.  I've seen CP's with 2 buttons for the spinner, so I'm guessing this is enough for it.  What games would "a couple of spinners" be good for?
Re Trackball: There are quite a few CP's that have 3 buttons for the TB, but I think this is only to be able to use it as a mouse?  Are there any games that actually use 3 buttons with the TB?
@alfonzotan:  Keeping my fingers crossed...   ;D
alfonzotan
« Reply #5 on: May 11, 2011, 02:35:07 pm »
Okay, somewhat more seriously...
If you're going to have a spinner, sooner or later you're going to want to play Tempest.  So that's two buttons at least.  Trackball?  Missile Command.  Three buttons.
I would suggest going with two or three buttons on either side of the trackball, that way you can play Asteroids (with left and right hands separated by the trackball) and similar shooters along with the rest.   And there's got to be room on there for a 4-way stick...
[PUTTIN'ONTHERIIIIIITZ!]
(Oh, regarding the OptiPac... it's much cheaper just to hack an old USB ball mouse and use that for a trackball interface.  Very simple, even for the soldering-challenged like yours truly.)
« Last Edit: May 11, 2011, 02:52:20 pm by alfonzotan »
« Reply #6 on: May 11, 2011, 04:03:39 pm »
If you are just looking to play a few casual multiplayer racing games, like Super Off Road, spinners and a couple buttons will work in a hitch. If you are one that really gets into racing games, I would just go ahead and plan a 3rd racing control panel with a pedal and shifter. :lol I would just take a look at the racing games in MAME and see what you would be interested in playing.
You have a point, but I think if you are going to make a panel with multiple spinners and a trackball, an OptiPac makes things pretty simple and is a small cost to have everything work without the effort. It's all preference though. :)
alfonzotan
« Reply #7 on: May 11, 2011, 04:11:30 pm »
True.  I'm no doubt influenced by having put in a straight-to-USB spinner and an old trackball hacked to a mouse board in my own CP.
« Reply #8 on: May 11, 2011, 04:48:32 pm »
It's definitely a good feeling accomplishing that yourself. I am currently working on a mouse hack spinner, when things start coming together, you can't help but feel good about the mouse hack!  8)
scofthe7seas
  • Last login:January 10, 2012, 11:33:10 am
  • I'm Eskimo. There's nothing here.
« Reply #9 on: May 11, 2011, 06:15:50 pm »
...are you planning on using your spinners for racing games as well?
I thought I was the only one who pathetically used a tiny spinner for driving games :D
My wife mocked me for this.  :'(
Talking like this could get you Shaolin Toe Stabbed in the throat.
« Last Edit: May 11, 2011, 06:19:23 pm by scofthe7seas »
  • Last login:April 28, 2024, 12:59:28 pm
« Reply #10 on: May 11, 2011, 06:29:16 pm »
Heh. I play Pole Position quite successfully with my TurboTwist 2!
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #11 on: May 11, 2011, 07:17:29 pm »
If you didn't have the optipac, I would say get one of these:
http://classicgaming.gamespy.com/View.php?view=Articles.Detail&id=206
then have your second CP be a dedicated Tron CP
