Author Topic: mortal kombat 1 and 2 questions  (Read 5081 times)
postmortem
  • Last login:July 03, 2020, 10:58:40 am
« on: May 04, 2011, 11:55:49 pm »
I have an MK2 arcade and I want to get an MK1 board and some kind of switching system so I can press a button to switch from part 1 and part 2. I had a few concerns..
1. whats the differance between the Y board and the T board for MK1? will I have a problem if I have an MK2 and an MK1 Y board in the same switcher? It has something to do with the kick harness. I think the Y boards were different or something. Kinda need an expert.
2. Can I use the same sound board for MK 1 and MK2, or MK2 and MK3? Or do they all have different sound boards?
thanks!
Cabs: Tron, MKII, MK4, KI2, Blitz99, TMNT, Pac-Mania, Defender, Mame Box.
PCBs: MK1, UMK3, Killer Instinct, Area51, Sunset Riders, Pit Fighter, Wargods.
Pins: Bride of PinBot, Attack from Mars, The Shadow
MXV
  • Last login:May 20, 2011, 12:26:06 pm
Re: mortal kombat 1 and 2 questions
« Reply #1 on: May 05, 2011, 09:54:52 am »
All 3 games used different boards, MK3 had no separate sound board, it was all on one board.
I don't know the Y and T stuff but you can easily just make adapters for the kick harness in your cabinet. I have a dedicated MK3 machine. MK2 board just plugs right in there and the kick harness functions the same, ditto for MK4. For MK1 I have an adapter for the kick harness so it matches what the board wants vs how the cabinet is wired.
  • Last login:May 06, 2024, 04:33:26 pm
« Reply #2 on: May 05, 2011, 10:30:46 am »
Talk to Malenko...  I think he has 4 MK's in one one cabinet.
  • Last login:Yesterday at 09:56:41 pm
« Reply #3 on: May 05, 2011, 12:57:05 pm »
Thats MK3Fan.
What MXV typed is correct. Both the T and Y boards are logistically the same, a JAMMA edge connector and the kick harness is all you have to worry about.  The kick harness for MK1 is the odd man out, its the same for MKII, MK3/UMK3, and MK4. There is a way to wire it up at the same time using resistors.
« Reply #4 on: May 05, 2011, 01:41:42 pm »
Also, you need to wire up the -5vs
postmortem
« Reply #5 on: May 05, 2011, 07:05:37 pm »
would it be easier to just get an MK1 5.0 T unit board? should that one be the same as MK2 and up as far as the kick harness?
also, how do i even connect the kick harness to these switching boards? Do I need some kind of special kick harness that splits to multiple connecters? Sorry im kinda a noob about this stuff.
this is the switcher im lookin at http://www.jammaboards.com/store/6-in-1-multijamma-switcher-pcb/prod_250.html
« Last Edit: May 05, 2011, 07:12:17 pm by postmortem »
« Reply #6 on: May 05, 2011, 08:05:35 pm »
No all MK1s have the same kick harness.you'll have to put resistors in line for the kick harnesses. I never bothered with a jamma switcher for the MK boards because you need to daisy chain solder the -5v   I dont play MK1 in my cab, but switching between MKII and UMK3 takes all of 5 seconds.
Search Multi MK on here and look for the thread by MK3Fan
postmortem
« Reply #7 on: May 05, 2011, 09:43:39 pm »
I guess I have more research to do. This video suggests that the T units use the same kick harness as MK2. What do ya think?
« Reply #8 on: May 08, 2011, 11:04:45 am »
Nope you are right, the Tunit boards did switch the kick harness, the MK manual I have wasnt for a T unit one. That video is by the user on this board that goes by the name MK3Fan
if you are going to use a jamma switcher, you will need to solder the -5V between connections. If youre going to just swap PCBs like in the video, then you just move the 2 connections
itobandito
  • Last login:April 29, 2022, 11:04:23 am
« Reply #9 on: May 09, 2011, 02:49:04 pm »
Yeah I have 5 mk board in my 6 in 1 switcher.  I believe the new 2 in 1 switchers have -5v wired if not you will have to solder a wire on to it to take the -5v.  As for the kick harness each board needs its own.  You then have to connect the kick harness's together somehow.  ( I twisted like wires together by twisting the wires on to each other, then soldering them together, I then took a few diodes (Mk3 fan vids say which ones on need) and soldered one on each like kick harness wire.  I then soldered a wire to the other end of the diode and connected that wire to the correct corresponding button.  There is definitely a cleaner way to this I am sure but it works.  The diodes restrict and feedback/phantom button presses or something like that.  but yeah MK3fans vids are a must watch for this.
