Main > Main Forum
mortal kombat 1 and 2 questions
Pages: << < (2/2)
postmortem:
would it be easier to just get an MK1 5.0 T unit board? should that one be the same as MK2 and up as far as the kick harness?
also, how do i even connect the kick harness to these switching boards? Do I need some kind of special kick harness that splits to multiple connecters? Sorry im kinda a noob about this stuff.
this is the switcher im lookin at http://www.jammaboards.com/store/6-in-1-multijamma-switcher-pcb/prod_250.html
Malenko:
--- Quote from: postmortem on May 05, 2011, 07:05:37 pm ---would it be easier to just get an MK1 5.0 T unit board? should that one be the same as MK2 and up as far as the kick harness?
No all MK1s have the same kick harness.you'll have to put resistors in line for the kick harnesses. I never bothered with a jamma switcher for the MK boards because you need to daisy chain solder the -5v   I dont play MK1 in my cab, but switching between MKII and UMK3 takes all of 5 seconds.
Search Multi MK on here and look for the thread by MK3Fan
postmortem:
I guess I have more research to do. This video suggests that the T units use the same kick harness as MK2. What do ya think?
Malenko:
--- Quote from: postmortem on May 05, 2011, 09:43:39 pm ---I guess I have more research to do. This video suggests that the T units use the same kick harness as MK2. What do ya think?
Nope you are right, the Tunit boards did switch the kick harness, the MK manual I have wasnt for a T unit one. That video is by the user on this board that goes by the name MK3Fan
if you are going to use a jamma switcher, you will need to solder the -5V between connections. If youre going to just swap PCBs like in the video, then you just move the 2 connections
itobandito:
Yeah I have 5 mk board in my 6 in 1 switcher.  I believe the new 2 in 1 switchers have -5v wired if not you will have to solder a wire on to it to take the -5v.  As for the kick harness each board needs its own.  You then have to connect the kick harness's together somehow.  ( I twisted like wires together by twisting the wires on to each other, then soldering them together, I then took a few diodes (Mk3 fan vids say which ones on need) and soldered one on each like kick harness wire.  I then soldered a wire to the other end of the diode and connected that wire to the correct corresponding button.  There is definitely a cleaner way to this I am sure but it works.  The diodes restrict and feedback/phantom button presses or something like that.  but yeah MK3fans vids are a must watch for this.
Pages: << < (2/2)
Go to full version
