Main > Main Forum
Any way to pimp out a Happ Bat Stick?
butteroj:
--- Quote from: RandyT on May 03, 2011, 12:29:40 pm ---
Just wanted to add something else. We also have some mirror polished and treated aluminum balls tops for the replacement shafts. These may not hold up as well as the stainless over the years, but they are much lighter. Some folks have opted for a heavier spring with the stainless balls, but that wouldn't be necessary with the aluminum.
I also have some anodized aluminum shafts for the HAPP and IL sticks in Natural, Black, Red and Blue. I'll try to get these up in the next couple of days.
When will these be up on the site?
RandyT:
I'll try to get this option up soon. In the meantime, however, the mirrored aluminum balls cost us the same as the stainless ones do, so if you want the aluminum, just order the "Versa-Ball Mirrored Stainless Ball-Top Joystick", and in the comments box indicate that you want the aluminum tops. If you want the anodized aluminum shafts, indicate that, and the color, as well.
If you are looking for the aluminum shafts and a Hand-Candy™ Balltop, I'll try to get those up in the next day or so. These will be a little less expensive than the metal balls tops.
RandyT
MAME TIME:
hey randy these are going to be happ shafts with handcandy tops?? if so im in
butteroj:
Also Randy, will these shafts work in a wico stick?
Subconscious:
--- Quote from: RandyT on May 18, 2011, 03:53:21 pm ---If you are looking for the aluminum shafts and a Hand-Candy™ Balltop, I'll try to get those up in the next day or so. These will be a little less expensive than the metal balls tops.
This is what I'm looking for. Can't wait! :applaud:
