Main > Main Forum
Need help with some Mortal Kombat II stuff
Pages: << < (5/6) > >>
Malenko:
you do it from the front. put the top in, and slide up, sit it on the little shelf with the notch. then install the metal L bracket over top of it, easy peasy
leapinlew:
--- Quote from: Malenko on June 11, 2011, 05:25:26 pm ---you do it from the front. put the top in, and slide up, sit it on the little shelf with the notch. then install the metal L bracket over top of it, easy peasy
Yeah, it's not working out that way for me.
Can anyone else confirm the glass size on their MK2 cabinet? You have multiple cabinets right Malenko? Any chance you're coming through St. Louis anytime soon?  :)
Malenko:
--- Quote from: leapinlew on June 11, 2011, 07:14:04 pm ---
Is there a meat up? Would you show? I kid I kid.
Want a youtube vid made or something? I mean you gotta have it a tight angle to slide it up. I measured the KI1, KI2, and MKII cabs, all 3 are the same size bro. Make sure you have the 25" as the horizontal?
xKalessinx:
I can confirm Malenko's measurements.  I just orderded and installed a piece of glass for one of my two Midway cabinets.
leapinlew:
Ok. Thanks for sticking with me, I found the issue.
I purchased the cabinet a few weeks back and it didn't have glass in it. The top part where the glass slides in was wedged and didn't allow enough room for the glass to slide up so I figured either the glass was too thick or to tall. I pryed the top piece free and I'm able to install the glass now.
Whew! That was a close call. Almost had to meat up with Malenko.
Go to full version
