Main > Main Forum
Is it possible - mame cab and jukebox?
BobA:
--- Quote from: ark_ader on May 02, 2011, 12:48:12 pm ---
--- Quote from: BobA on May 02, 2011, 09:26:29 am ---Thanks for the clarification. Touchscreens use USB or Serial connections. If it only has serial then you definately will not be able to get it to work with the xbox. If it has USB we are back to my original caution that an elo driver will not work on an xbox so you would probably be better off with a separate mini itx motherboard.
:blah:
ark_ader:
--- Quote from: BobA on May 02, 2011, 05:38:18 pm ---
:blah:
