Main > Main Forum
Is it possible - mame cab and jukebox?
Pages: << < (5/6) > >>
BobA:
No I just said it does not work for elo since he already has a 15 inch screen and elo is the most common around. :dunno
BobA:
Maybe the OP can specify what touchscreen he has so we can get on with helping not guessing. ;)
notroubleclubber:
Guys - dont start an argument!!!
The guy on ebay selling the screen says it uses ELO drivers though i dont think its an ELO screen.
Also, it looks like from the picture that it may only be serial connection though i could be wrong - i wont know until it arrives.
BobA:
Thanks for the clarification.   Touchscreens use USB or Serial connections.   If it only has serial then you definately will not be able to get it to work with the xbox.   If it has USB we are back to my original caution that an elo driver will not work on an xbox so you would probably be better off with a separate mini itx motherboard.
ark_ader:
--- Quote from: BobA on May 02, 2011, 09:26:29 am ---Thanks for the clarification.   Touchscreens use USB or Serial connections.   If it only has serial then you definately will not be able to get it to work with the xbox.   If it has USB we are back to my original caution that an elo driver will not work on an xbox so you would probably be better off with a separate mini itx motherboard.
 :blah:
Go to full version
