Author Topic: Self adhesive vinyl  (Read 3831 times)
mytymaus007
Self adhesive vinyl
« on: April 18, 2011, 10:28:07 pm »
Does anyone know where i can buy large sheets of Self adhesive vinyl like on a Donky Kong cabinet. i was just at the Nascar Speedway park in Myrtle Beach and i noticed that the donky kong cab had vinyl siding. That what i want to use to cover my cab.
DillonFoulds
Re: Self adhesive vinyl
« Reply #1 on: April 19, 2011, 01:07:12 am »
Isn't that what http://www.gameongrafix.com prints onto?
LeedsFan
  • Last login:January 17, 2021, 06:14:23 am
« Reply #2 on: April 19, 2011, 02:06:49 am »
I thought original DKs were made with blue laminate. Is that what you mean?
mytymaus007
« Reply #3 on: April 19, 2011, 10:27:11 am »
The DK cab had Blue Vinyl as a base then the artwork was on top of that.  Does anyone have a DK cab to confirm that the blue is Vinyl if so where can I find this.
Ambaratur
  • Last login:February 12, 2019, 08:55:13 am
« Reply #4 on: April 19, 2011, 12:35:32 pm »
I have an DK cab.  Manufactured in 1984.  It is not vinyl nor is it laminate.  It is a type of enamel painted on the wood.
RandyT
  • Last login:May 06, 2024, 12:12:44 pm
    • GroovyGameGear.com
« Reply #5 on: April 19, 2011, 01:02:04 pm »
Check out a Sign Supply house.  The vinyl you are looking for is used for signmaking plotters/cutters.  It's not original to the cabinet, but was probably used in lieu of paint.
I have laminated a cabinet sized project with vinyl, and it's tricky to do.  Look up the "wet method" of vinyl application if you go this route, as it's bound to be easier.
RandyT
mytymaus007
« Reply #6 on: April 19, 2011, 02:30:35 pm »
Yeh Baby I figured out the solution. I will attempt to paint over Self adhesive Vinyl. Check out this tread. This should be a saved thread if its not already.
http://forum.arcadecontrols.com/index.php?topic=70324.0
« Last Edit: April 19, 2011, 02:32:33 pm by mytymaus007 »
« Reply #7 on: April 19, 2011, 06:38:03 pm »
Your painting over vinyl? Why? I just primer/sanded/paint
Billkwando
  • Last login:February 08, 2024, 10:42:45 pm
« Reply #8 on: April 19, 2011, 07:05:36 pm »
I know what you're talking about:
http://www.classicarcadeonline.com/donkeykong_8.html
"If you believe you're up against a swordsman who is proficient in the Way, you will lose."-Miyamoto Musashi
mytymaus007
« Reply #9 on: April 19, 2011, 10:52:15 pm »
i was thinking of using vinyl until i found this thread about painting.
RandyT
« Reply #10 on: April 20, 2011, 04:51:53 am »
You might as well.  Unless the vinyl used is very thick or rigid like actual laminate, you would see every imperfection in the surface underneath.  If you have to go through all of that prep work anyway, there's not much difference other than the fact that paint will probably hold up better and cost less.
