Main > Main Forum
Self adhesive vinyl
RandyT:
--- Quote from: mytymaus007 on April 19, 2011, 10:52:15 pm ---i was thinking of using vinyl until i found this thread about painting.
You might as well. Unless the vinyl used is very thick or rigid like actual laminate, you would see every imperfection in the surface underneath. If you have to go through all of that prep work anyway, there's not much difference other than the fact that paint will probably hold up better and cost less.
