Main > Main Forum
U360s; Anyone use WITHOUT restrictor plates?
Gray_Area:
--- Quote from: VanillaGorilla on April 22, 2011, 08:17:55 am ---
--- Quote from: Gray_Area on April 22, 2011, 12:55:21 am ---Gauntlet is not analog.
Technically, neither is sinistar, they both used 49-ways. So they are matrix based; IE supporting acceleration in movement as the stick is pushed increasingly to the outer regions of its travel. An 8-way stick will not be able to replicate this behavior. A u360 will.
Oh. I don't recall that, as I only played the game in the arcade once or twice. There is no 'analog' type feature in MAME in-game options, and there seems to be no difference in movement when I use the analog map.
--- Quote from: idsane on April 23, 2011, 01:18:33 am ---I'd like to try both, but $14 a piece? Yikes!
Check out Lizard Licks.
ragnar:
I still want some restrictors to be made that have more freedom of movement. I tried no restrictors but I had problems with extreme joystick positioning (diagonals for exmaple) giving strange results. the anal,og values would go from 0 to 128 for example but if you moved it further it would start dropping from 128 to maybe 64.
I would buy new restrictors in a heartbeat that gave a range of motion between no restrictor and current restrictors
