Author Topic: Dilemma: the screen  (Read 990 times)
Stormdemon
  • Last login:June 10, 2004, 01:20:16 pm
Dilemma: the screen
« on: August 27, 2003, 07:18:33 am »
I'd like to buy a TV for use with MAME. I'm not sure, however if I should go for a new model with flat screen and 100hz or pick a more old looking model with convex screen and 60hz (it's cheaper, but that's not the point here). The idea of 100hz is tempting because I think my eyes wont suffer after long periods of gameplay, specially when you sit close to the tv, but it definitelly isn't as authentic as 60hz. Same happens with flat screens: they're better in terms of picture quality and don't have problems of picture not fitting in the screen. I think the best would be an old looking tv with rounded screen corners and convex screen, but featuring 100hz. I don't know if there's such a thing available in the market.
paigeoliver
  • Awesome face!
Re:Dilemma: the screen
« Reply #1 on: August 27, 2003, 07:44:14 am »
Try the monitor video forum. Every concievable type of display has been debated there.
http://www.arcadecontrols.org/yabbse/index.php?board=4
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
« Reply #2 on: August 27, 2003, 12:21:32 pm »
I was a little worried that the this would happen or the picture wouldn't look as good when you are so close to the TV.  However, neither was a problem at all.  I have a 27" Sharp 27U-S600 TV using s-video w/ a Radeon 7500.  I also have had no problems with the picture not fitting the screen.  I'd recommend the convex screen.
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
« Reply #3 on: August 27, 2003, 01:25:59 pm »
check if your front end of choice will run on TV resolution too.
I've heard that emulaxian doesn't like it...   I've got mine set up with an old 17" pc monitor, as a temporary solution.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
