Main > Main Forum
Super Mario X
ids:
--- Quote from: Jack Burton on April 07, 2011, 11:05:29 pm ---Seems like it crashes in any resolution under 1024x768 in Windows XP.
Good to know - tried Win7/64b last night on my cab at 800x600; after the launch screen, I got nothing. I'll try upping the res.
thx
markronz:
--- Quote from: garwil on April 07, 2011, 03:58:40 pm ---Yeah, it's a great game but I've never been able to get it to launch from a FE.
I was just playing around with this today. It's not a perfect solution, but you could use a VBScript file to launch it. I have a .vbs file with this code in it:
--- Code: ---Set WshShell = WScript.CreateObject("WScript.Shell")
WshShell.Run "C:\Users\Administrator\Desktop\SMBX\smbx.exe", 1
WScript.Sleep 200
WshShell.SendKeys " "
--- End code ---
You will see that first screen flash still, very briefly, but it should launch the game. I think that launching via this method may cause some issues with LedBlinky, if you use that, and intend to light up some controls though. But it's a start. You should be able to add it to a front end that way, though I haven't fully tested it yet.
This whole "only over 800x600" resolution is a problem though. The rest of my cab and all the software is configured for 800x600...
NipRing:
My Tri-sync nanao via vga is only 640 x 480 :-[
ids:
Tried upping res to 1024x768, Win7/64b, using TV
Game worked fine. However, it started in a window that looked ~800x600 :) The "full-screen" mode made it full-screen, but didn't change the game's resolution, leaving a big unused area. In windowed mode, maximizing the window made it do a real full-screen. Fortunately, controls are configurable, so it should work fine on most cabs.
Now, just need a launch script which can flip resolution prior to starting the game ;D That, or fix the game to run in lower resolutions.
Nimbus:
After seeing this thread I downloaded Super Mario X. I finally played it today and it is a BLAST. I just played it on my computer with an old Logitech controller.
I can't believe that a game like this was put together by fans. It is so much fun, especially if you are a huge fan of the Super Mario Series. AMAZING!!!
