Main > Project Announcements
First Stab at a Cabinet - Bartop
Pages: << < (2/3) > >>
DNA Dan:
That's slick! I am planning on doing a two player bartop with my leftover parts from my upright build and this clearly addresses the width problem for 2 players on a bartop. What joysticks and buttons did you use?
upprc04:
--- Quote from: DNA Dan on April 01, 2011, 11:18:18 am ---That's slick! I am planning on doing a two player bartop with my leftover parts from my upright build and this clearly addresses the width problem for 2 players on a bartop. What joysticks and buttons did you use?
Joysticks: Sanwa JLW-TM-8
Buttons: Original Happ Horizontal pushbutton
Termin8tor:
Looking good, but I would paint the piano hinge black. ;)
upprc04:
The artwork showed up and looks pretty good.  I wasn't able to get the outlines lines up perfectly, but pretty close.  The black on the marquee didn't show up as solid black and you can tell if you look close.  But that may just be an overall issue with black.  Also, the CPO was about a quarter inch short width wise, but i went ahead and went with it and you can't really tell unless you look very close.  Just need to spray the hinges black and put latches or something to secure the control panel.  And then the constant work of getting the software to look the way I want.
DNA Dan:
Great job! Looks very clean to me in the photos. I like the simplicity of the CP.
What type of paint/sheen did you use for the black?
Go to full version
