Main > Everything Else
I bought a Dremel
<< < (6/7) > >>
Benevolance:
After watching Manny Malholtra take a puck in the eye, I wear safety goggles all the time.
The Dremel was excellent carving out the new marquee on my arcade cabinet. It took a little while to get the hang of it. I find it very useful for smaller jobs, where I don't want to bother getting out a larger, better tool.
My kit has a gazillion attachments. I do not know what half of them do. It's great that they color coded the sandpaper/grinding attachments, but it would have been even better if the book wasn't in black and white. It will take me a while to sort out which attachments are most useful for what purpose. In the meantime, I think I found an attachment for writing forum posts, but it isn't working very well. Maybe it's not compatible with my monitor? All I get is a lot of scratches and smoke.
Ond:
Yeah you can double up those fragile cutting discs as Xiaou2 says, less shattering.  Sometimes the stronger reinforced cutting wheels are too big for the job.  I like using mine with the flexible extension for more control.  They have their uses, somewhere in my current project I used mine to cut off all these screw ends on the inside of panels I'd made, worked a treat.  I'm not very impressed with the router bits which are really pricey and messy to use, but then I don't use the special little jig you're meant to use with them either.
--- Quote from: Benevolance on March 31, 2011, 03:24:03 pm ---I think I found an attachment for writing forum posts, but it isn't working very well. Maybe it's not compatible with my monitor? All I get is a lot of scratches and smoke.
That will just be a driver issue, you need to download the latest one compatible with your OS  :P
Donkbaca:
--- Quote ---After watching Manny Malholtra take a puck in the eye, I wear safety goggles all the time.
I do too, never know when some ---maternal-smurf--- will sneak up on you and chuck a puck in your eye....
ChadTower:
--- Quote from: Donkbaca on March 31, 2011, 07:31:59 pm ---
I hate those chuck pucker ---maternal-smurfs---.
Donkbaca:
Wearing goggles right now, its april fools day, thats the main day when the puck chucker ---maternal-smurfs--- are out to get a sucker.....
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
