Author Topic: having problem with ultralux pushbutton !!(ultimarc)  (Read 1354 times)
soyeux28
  • Last login:April 13, 2012, 12:08:51 am
« on: March 28, 2011, 09:30:00 pm »
ok so i will try to explain this as clear as i can with my so-so english lol
i ordered from ultimarc some led pushbutton , led works fine , but when i try to insert the led into the push button, its impossible to align the little cherry button on the black connector , with the white button that is activated when you push the button that hit the little cherry pushbutton !!1
i can add pitcure if needed , but the flash kinda screw the pic
thanks for the reply !!!!
BobA
  • What Me Worry?
Re: having problem with ultralux pushbutton !!(ultimarc)
« Reply #1 on: March 29, 2011, 09:15:24 am »
Send Andy an email with info on your problem if you cannot resolve it.   It looks like the bayonet holder for the light holds the switch in position and the plunger on the pushbutton should come down and push on the microswitch actuator if the bayonet is in the correct position.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: March 29, 2011, 12:09:24 pm »
You're not twisting hard enough. The first time you install the bayonet, it takes a decent amount of torque to lock them in.
soyeux28
« Reply #3 on: March 29, 2011, 06:21:14 pm »
i twist as hard as i can (i could break it if i wanted believe me lol) the "ring" untight when i try to tightined more...ill try to make a small video to explain it !
Ginsu Victim
« Reply #4 on: March 29, 2011, 07:56:50 pm »
I guess you'll have to. I don't understand what you're doing wrong, but you're definitely doing something wrong.
soyeux28
« Reply #5 on: March 29, 2011, 07:57:52 pm »
probably ( i know im doing something wrong )!!! i was posting the video as you replyed lol
ok if anybody wants to check it out
my first youtube video woot woot....man youtube is now force you to associate with a googlemail.... lame!
anyway thanks for the help everyone!
Ginsu Victim
« Reply #6 on: March 29, 2011, 11:16:49 pm »
You didn't twist it far enough, because it isn't locked into place (I see some looseness). Believe me, you're not going to break it....you need to twist it clockwise more.
soyeux28
« Reply #7 on: March 30, 2011, 06:56:21 am »
it worked .. when you said your not going to break it , i told myself :whats the worst that can happen ?? break it and buy another for 4$ lol
thank you very much !
(me and my fear of breaking everything lol )
Ginsu Victim
« Reply #8 on: March 30, 2011, 10:40:06 am »
Glad you listened. :)
