Author Topic: Newbie here, please help  (Read 953 times)
twault
  • Last login:July 23, 2011, 03:32:12 am
« on: March 20, 2011, 07:12:04 pm »
2 questions:
The first: I have 2 WICO ball-top joysticks. How can I tell if it is a 4-way or 8-way? Is there a website with pics? I'm not real good on the terminology used as far as parts, so please bear with me. I can post pics if this would be helpful.
The second: Can you use (2) of the 2 player ipacs to play a 4-player game?
PsychoMikey
Re: Newbie here, please help
« Reply #1 on: March 20, 2011, 07:26:48 pm »
You could use 2 ipac2 interfaces if you reprogram and make sure buttons don't interfere. I would highly recommend tu use the ipac4 instead. It's cheaper, and it will be easier to use for that purpose.
Have never used WICO joysticks but in general:
A 4 way joystick can move left, up, right or down. It has a diamond shaped restrictor.
A 8 way joystick can also move left up, up right, down right and down left. It has a square restrictor.
Paul Olson
  • Last login:Yesterday at 03:19:08 pm
    • Paul's Arcade
« Reply #2 on: March 21, 2011, 11:19:26 am »
You can tell by the hole in the bottom of the base. 8-way is round, 4-way is diamond shaped. Also, 8-ways are usually black, and 4-ways are usually grey. I haven't seen any that differ from these colors, but I have seen a couple of black bases sold as 4-way, so not to sure.
Savannan
  • Last login:December 22, 2012, 10:53:06 pm
« Reply #3 on: March 21, 2011, 11:37:51 am »
if you move the joysitck diagnal...do you hear 2 clicks or none ... none = 4 way ... 2 = 8 way
twault
« Reply #4 on: March 21, 2011, 01:49:18 pm »
Thanks all! I will have to try it when I get home. Has anyone every seen a Wico 4-way joystick with a round hole?
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #5 on: March 21, 2011, 07:54:21 pm »
+1 to what Paul Olson said.
Have never encountered a black base that was actually a 4-way in the real world, but have seen then listed as such on eBay.
If you hear *any* clicks, then you almost certainly have 8-ways since I don't think Wico made a 4-way stick using microswitches.
Working: Not Enough
Projects: Too Many
Progress: None
