Author Topic: update mame yay or nay?  (Read 2695 times)
ccmathome
  • Last login:February 25, 2021, 12:40:52 am
« on: March 14, 2011, 11:05:16 pm »
Right now i'm running mame .134 any reason to update to .141?
DillonFoulds
Re: update mame yay or nay?
« Reply #1 on: March 15, 2011, 12:31:23 am »
Mamedev.org -> Latest Release -> What's New
Check the MAMEDev change logs and see if anything there gives you a reason to update.
mytymaus007
« Reply #2 on: March 15, 2011, 08:24:08 am »
Donkey Kong 2 :P
Dervacumen
  • Last login:February 13, 2019, 10:11:11 pm
  • Home of Three Squares dice game
    • Beaker Games
« Reply #3 on: March 15, 2011, 01:08:04 pm »
That's the only accurate answer to this question.  It's a personal choice, so I'm still on .96 because of a Robotron fix.  There may be more accurate versions now, but with my skill set it's inconsequential to me.
Bringing to life a child's imagination.
eds1275
  • Last login:May 03, 2024, 12:05:34 pm
  • Rock and Roll!
« Reply #4 on: March 15, 2011, 01:15:36 pm »
I'm on 137 with no reasons to update. I was actually on 128 with no reason to update and then I did... and it was a PITA just to get functionality back to how it was.
8BitMonk
  • Last login:October 19, 2023, 05:27:00 pm
« Reply #5 on: March 15, 2011, 02:40:11 pm »
I've found it easier to browse the New & Changed page on MAWS vs. the change log. You can set a range from the version you have to the version you are considering updating to. http://maws.mameworld.info/maws/
« Last Edit: March 15, 2011, 02:43:39 pm by 8BitMonk »
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #6 on: March 15, 2011, 03:04:59 pm »
I may be mistaken, but I always thought Robotron was fixed in .99... You might not notice if you don't play both versions side-by-side. The old version runs a bit too fast.
Dire Radiant
  • Last login:March 25, 2011, 03:11:36 am
  • Cor, chief!
« Reply #7 on: March 15, 2011, 08:39:59 pm »
Its always a dilemma. On the one hand if there's no compelling reason for updating then you probably shouldn't (I'm still running 0.95 in my cab and haven't seen a good reason to update yet) On the other hand, are we not men? Are we not involved in a hobby which involves building things and tinkering with them? Surely then our motto must be "If it ain't broke, fix it until it is."
Osirus23
« Reply #8 on: March 15, 2011, 10:07:08 pm »
I don't update unless support for a game I actually want to play is added/improved.
ccmathome
« Reply #9 on: March 15, 2011, 11:48:50 pm »
LOL thats true. I'm using mala for my FE but thinking of going over to HS, there xmls use the .141 set and I dont really want to rename tons of stuff and might move up to a 64bit os on my cab still unsure.
Been reading on win7 64 with .141 you get a 10-15% boost and a 20-30% from 64 bit os something like that.
Dervacumen
    • Beaker Games
« Reply #10 on: March 16, 2011, 02:03:07 am »
You're likely correct, but I think at the time I specifically chose .96 because I thought the speed problem was fixed in that version.  At any rate, I will now use your tidbit to justify why I suck so bad when friends are over.  Heh.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #11 on: March 17, 2011, 12:28:46 am »
Well, sad but true: with Robotron, you either suck or you don't. It's just a matter of how badly.
-Banned-
DillonFoulds
« Reply #12 on: March 17, 2011, 11:11:53 am »
For MAME, it's a nice performance boost, but it can be a PITA for other emulators. Personally, in my hyperspin wheel (50 systems?) i've only run in to about 5 platforms that gave me issues with regards to Windows XP 64. I'm sure before I call my cab finished, i'll have OS images for XP, XP64, 7 64, and 7 32...
