Author Topic: Slikstik Quad Control Panel  (Read 4335 times)
planbee
  • Last login:June 08, 2012, 10:25:17 pm
« on: March 13, 2011, 03:43:42 am »
Firstly I know this company no longer exists, I am trying to find any sort of plans for this control panel as I am building a UAII cabinet and I like the look of the old Slikstik CP. I'm doing everything myself, all the building etc so if anyone could provide anything to help me out I would be most appreciative. I have done a search around on the internet but I have found very little on it.
Thanks again,
Jason.
Gatt
  • Last login:February 04, 2020, 08:24:38 pm
Re: Slikstik Quad Control Panel
« Reply #1 on: March 13, 2011, 07:38:53 pm »
http://www.avsforum.com/avs-vb/showthread.php?t=818646
There's a pretty clear image of it.  I have a modified slikstik classic blank sitting around,  gotta warn you,  these things are *really* big.  The classic is very similiar to the quad except the quad is longer and has a different arc cut for the top part.  Mine has the trackball,  spinner,  dedicated joystick,  asteroids buttons and all.
The classic measures in at...
17" width at it's maximum
~44" in length
with depth ranging from 4 3/4"(front) to 5 1/2"(rear)
You'd need to add width to hit 4 players,  but the rest of the measurements will work.  I've gotta ask though,  are you really sure you want this?  I ended up decided the thing was way too big to be used,  felt like I was trying to play games from the other side of the room. I suppose it would be workable in some sort of sitdown design,  but for anything else it's just way too big.  At nearly 4 feed long,  you've got people sitting almost 2 feet away from center,  it's really awkward.
planbee
« Reply #2 on: March 16, 2011, 01:17:41 am »
Well I'm a bit stumped now. I realize the quad CP is 4 feet wide, though I don't know if I actually know if it's too big as I haven't made a template or anything yet.
I cannot seem to find a quad CP design which I'm fond of that will fit a Ultimate Arcade II cab that has DIY construction plans available. Mameroom.com only offer quad CP's to buy complete, which I'm sure are the same design as the old Slikstik ones.
I'm open to suggestions for a quad CP that will fit a UAII cab if someone has anything I can see.
Jason.
jasonbar
  • Last login:July 30, 2023, 02:52:55 am
  • Dr. Inferno
    • The Infernolab
« Reply #3 on: March 16, 2011, 03:31:07 pm »
I got a SlikStik Quad before they disappeared.  I've been very happy with it.  I've modified it heavily.
I have several photos of it here: http://s242.photobucket.com/albums/ff97/infernolab/Arcade%20Game/?start=all
Some of them are nice plan view photos that you could use to recreate it on your own.
-Jason
llars
  • Last login:May 02, 2011, 02:01:46 pm
« Reply #4 on: March 16, 2011, 07:18:44 pm »
Jason.
They do sell blank quad panels starting at 150.00 depending on options. Price goes up if you want plexi or custom holes etc. Plus it's designed for the UAII.
http://mameroom.com/Products_Quad_Kit.asp
scream1973
  • Last login:July 25, 2014, 10:28:46 am
« Reply #5 on: March 16, 2011, 07:51:07 pm »
Saints new book has the old quad plans for the UAII in them
Gray_Area
  • -Banned-
  • -Banned-
« Reply #6 on: March 17, 2011, 12:42:55 am »
-Jason
Wow. Now that's a frankenpanel.
-Banned-
fallacy
  • Last login:March 23, 2024, 12:27:45 am
« Reply #7 on: March 17, 2011, 03:00:46 am »
ya http://mameroom.com/Products_Quad_Kit.asp is using the Slikstik design. I am pretty sure that it is exact.
planbee
« Reply #8 on: March 18, 2011, 07:52:19 pm »
Yeah it is, though it doesn't really help me with building one.
