Main > Project Announcements
Donkey Kong Mame Conversion
astroone:
Yes please width and length also on the back there's a cut grove that slides into the cab also how far is the inlay on the board a bottom measurement should make it close
Thank You Nimbus
Nimbus:
The Donkey Kong control panel is roughly 22 3/8 x 8 1/4. Those dimensions are not including the piece of T-molding on the edge of the panel. The slot cut into the bottom back of the panel that allows it to slide into the machine is ~1/8 inch deep and 31/32 wide.
Hope that helps!
astroone:
Nimbus you are awesome
Thank You :cheers:
astroone:
Went to Home Depot and got some 5/8" particleboard closes thing to 9/16" had a piece of T-Molding with me
Plus it was also cut at Home Depot ;D
Got Home and found out it was a little to wide so I had to trim an 1/8"
PLus Used a Skill Saw to cut the notch out
Couple coats of primer with First Coat of black Paint on will do another coat tommorow
Here's what it look's like :cheers:
opt2not:
I'm confused. Who's project thread is this? Rolpa's or astroone's?
